Question about Water Water Heaters
Hi I have a ecoTEC plus 824 and I have heating but no hot water & pressure is in the red....any suggestions
    Master:
  • 552 Answers
Pressure in red is not good - evacuate building.
it must be heating and output is blocked otherwise pressure would not rise.
OR input pressure is too high and pressure is disabling heat.
Posted on Dec 09, 2014
The heating element continues to heat even after the hot water tap is turned off thus popping the thermal switch. The red light is off on front of unit but you can hear the water heating. Any ideas?
check the pressure control that switches the element on or off
if it is faulty then it switches on when the tap is turned on dropping the pressure but it will not recognize that the increase in pressure when the tap is turned off so it keeps heating the water.
Apr 07, 2015 | Stiebel Eltron TEMPRA 24 Tankless Water...
Heating and hot water only warm. I'turned dials up and altered thermostat but nothing helps and pressure dial keeps going into red HELP
Check your dip tube.
the higher up the dip tube is broken, the colder the water will be.
Knowing the make and model of heater will help.
Mar 09, 2015 | Water Water Heaters
Vailant ecotec plus 837 - Water pressure and temp is too high
Pressure inside the tank will rise along with the water temperature. As the water inside cools the pressure will wane until the heating element turns on and reheats the water with a subsequent rise in pressure. Running the hot water at the same time will draw heat energy from the boiler and lower the internal temp and pressure as well.
Jan 21, 2014 | Water Heaters
Boiler vaillant ecotec 824 R1 no power
USE A ELECTRIC METER AND CHECK FOR 120 VOLTS AT CIRCUIT BOARD AT LINE IN AND COMMON , IF YOU DO HAVE 12 0 VOLTS THE LOOK FOR TAPPINGS FOR 24 VOLT OUT PUT MAYBE A BAD TRANSFORMER OR CIRCUIT BOARD
Jan 11, 2014 | Water Heaters
Currently have leaking expansion tank and have shut off main water to minimize water in basement (also have bucket under leak). Have forced hot water for heating house if have main water off can we keep...
HI sorry its shot, they go every now &then.You can run it like you say temporary BUT the boiler needs low pressure to force heat @10 or 12 p.s.i. This pressure will leak out of the hole and you eventaully loose heat & get noise.If you got a pinhole leak in tank.With the main off.Slow it down with duct tape or a rag if you can and leave water on.
Mar 30, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
Water Heaters Logo
75 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
