My bush washing machine fills with water drains water want wash.
Nothink yet
    Master:
  • 511 Answers
Timer controls it so it is either that or drum drive system-u didn't say if it is or isn't agitating or spinning
Posted on Dec 09, 2014
Watt can I try water fills and drains fine just want wash I have a bush new machine 8kg load
something wrong with the motor or its connections to the controller board
or the controller board motor control parts have failed
its a job for a tech
if its under warrenty then get back to the supplier {like argos etc} or the maker under makers warrenty
Dec 09, 2014 | Washing Machines
Tip
Washing machine filling with water on its own!!
From time to time washing machines fill with water on its own.... one of the things that can cause this problem is the drain hose being too low,this allows water to run from the sink back into he drum filling up the machine.To cure simply.. raise the height of the drain hose........
on Apr 06, 2010 | Washing Machines
Indesit wie 147 washing machine wont empty water it dose every think else but it got stuck and had an error of 5 with water stuck in drain some as looking at the preasure pipe blew down the pipe an no...
It really does sound like you have a blockage somewhere even if you cant feel it. You may need to remove the pump and the pipes to be certain. Try laying the drain pipe on floor level. If it drains then there is definately something in there that needs to be removed. Let me know if you need any more help.
Oct 20, 2011 | Indesit W 123 Front Load Washer
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
Problem with a indest wil143s
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 06, 2009 | Washing Machines
Washing machine fills with water when not in use.
You have an open solenoid on your water valve where the fill hoses connect. Change the water valve and you should be good.
Jul 25, 2008 | Washing Machines
Water gets drained automatically without fills the water
HI there. You drain out pipe need to have a kink and the kink need to be higher than the highest point of when the machine is filled with water or else gravity will let the water drain out as you fill it up. HOpe it works.
Feb 05, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
