Question about Gemmy 9 Desktop Buck The Animated Trophy
Can the circuit board in the gemmy animated trophy buck be repaired?
Switched circuit boards out and everything works fine. Tried circuit board in another gemmy buck and did not work. The buck head moves with the wireless mike but nothing else.
    Master:
  • 552 Answers
Anything can be repaired - it is a cost issue.
Posted on Dec 09, 2014
  • Dylan Schmidt
    Dylan Schmidt Apr 05, 2016
    That is untrue, the circit boards can not be replaced on these things, the microcontroller would have to be re programed with the song and movement
Hour, minute and second hands don't work, why?
Yes, there are two batteries in the 19093 (Compendium Hybrid). The first battery (CR2025) is visible as soon as you remove the back cover plate. The CR2025 controls the digital half of the watch and the back light. The second battery is underneath the circuit board that the CR2025 is connected to. There are 6 small screws that will need to be removed to lift the circuit board and gain access to the second battery. The second battery is an SR626SW.
Aug 22, 2014 | Watches
I have a seiko stop watch s129 that only has a streight line going through the middle of the screen horizontal
The LCD is having issues. The Seiko Service Center is the only place to repair this watch. Contact them at:
(800) 722-4452
Jan 19, 2011 | Seiko S149 Stopwatch with Built In Printer
The battery of my XG-55 is down. I tried with several watch repair labs, but they told me that after changing the battery, the watch doesn't start again. Any advice?
When you change the battery on this watch you have to short the circuit board. You need a fine pair of tweezers and you need to look on the circuit board for an arrow or bare spot, put 1 end of the tweezers on that place on the circuit board and the other on the battery at the same time. that should do the trick if the battery was installed correctly and the battery is good.
Nov 18, 2009 | La Crosse XG-55 Wrist Watch
My Citizen Navihawk analog hands work, LCD Blank??
Being able to tap it and bring it back is a sure sign that there is a contact problem most likely in the circuit board. This is the worst case scenario. I would try going to a watch maker/technician to see of having the watch AC'd or reset fixes the problem. If not then I would have them look at the circuit board/movement. This may have been damaged during battery placement from too much pressure.
If you have trouble finding a qualified watch maker/technician you can go to Citizen.com to look up their service center or an authorized service center near you.
Sep 21, 2009 | Citizen Navitach JQ8020-52Y wristwatch
I have a Timex expedition chronograh. Every thin
The nice thing about Timex is they have a 12 month warranty that covers just about everything. If you have had the watch longer....
Get the batteries checked. Battery life is typically about 2 years.
If the battery is fine then you can try having the watch reset but in most cases the LCD board or circuit board is damaged the watch has to be replaced to have it function correctly.
Sep 16, 2009 | Timex Expedition 84601 Wristwatch
I recently had my battery changed on a timex expedition adventure tech altimeter watch, now the chime doesn't work and the alarm doesn't beep. Please help. Thank you.
You can attempt to have the circuit board reset if it has an "AC". This may or may not fix the problem. Usually when a sound board goes out you have to replace the whole circuit board or movement.
Sep 14, 2009 | Timex Expedition Adventure Tech Altimeter...
It stops for a few minutes then runs well again
The problem that you have is with the watch's circuitboard. Inside this circuit board you have what is called a quartz chrystal, which transmits direct pulses to the circuit board, as for the watch to run properly. And as it is not at all possible to regulate or adjust the function of the crystal's pulses, which itself is integrated in the circuit board, there is no other way than to replace your watch's circuit board.
P.S. If you do not have the necessary watchmaker's knowledge to fix this yourself, you will have to find your nearest watch repair shop, and ask for help.
Please rate if this was helpful.
Jul 30, 2009 | Timex Expedition T41261
Polar F6 - Battery replaced, display corrupt after watch loads.
I had the same problem and attempted what banjodoug suggested above. It did not help. I had a faint display even before I re-inserted it into my watch frame. I surmised it wasn't the battery position.
I then took apart the damn thing and put it back together several times, each time rushing to push the setting/center button only to derive the same problem over and over.
I then took it apart one more time and pinched in all of the sides of the metal frame that holds it all together, thinking that I had a bad ground. After I did that, I reassembed it and waited. The display came on with the test display and then eventually went to the standard display on its own and all was good to go.
I suspect the issue was solved by correcting an improper ground and a proper initialization process - both solved by the steps I took above.
Hope it works for you!
Feb 21, 2009 | Polar F6 Wrist Watch
Hello I have a hitachi 50v500 and the repair shop says it needs a power supply circuit where can I buy one of those they just put in a light engine 11 months ago which Hitachi covered the part but I paid...
it seems that the TAG was on problem on watches...
anyway may i know the exact model of the unit.. and please add more info on this...
micro
Jun 18, 2008 | Watches
Gemmy 9 Desktop Buck The Animated Trophy Logo
129 people viewed this question
Top Gemmy Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Gemmy Watch Expert? Answer questions, earn points and help others
