Question about Toshiba Cell Phones
Instead simcard on Toshiba tablet model no AT-7
It has a port written micro sd is that where to insert the sim card?
    Master:
  • 552 Answers
NO - SD card is for expanding memory.
Posted on Dec 09, 2014
Does the zeepad 7DRK carry a sim card
this site has the specs for your tablet, but it doesn't appear to be either 3G or 4G capable it does have a slot for a micro SD card
http://www.pcworld.com/product/1430414/zeepad-7drk-tablet.html
Nov 04, 2015 | Tablets & eReaders
How do I add extra memory to my tablet with s micro card
Greetings,
First of all what kind of tablet do you have? Most tablets that support Micro SD cards have a port on the back where you insert the card. Some tablets have it under a protective cover sometimes next to other ports for charging or USB etc.
Post what kind of tablet you have and we can better assist you.
Thanks.
Chadman
Feb 24, 2015 | Tablets & eReaders
Can't insect my sim card, can u help
I'm assuming you mean "insert" rather some crawly creature. SD cards are designed to only fully seat in one way. I'd suggest turning the card over and trying again. Take a flashlight and look in the slot to be sure something isn't blocking (remember VCR's,lol). It should slide in with little pressure, the last 1/4" might feel tighter but that's a spring compressing to take it out. Finally have you tried the card in another machine?
Good luck
Nov 27, 2014 | Irulu 7" 4gb Google Android 2.3...
Insert micro sd card
It only fits into the slot one way. If it doesn't slide in smoothly, don't force it; try turning it around, or inserting it face down--one orientation will work.
Aug 11, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Every time I insert my micro sd card into the required spot on my tablet brand Thomson model number qm7348g it heats up and gets that hot I burn my fingers trying to get it out With in 10 seconds of me...
your micro sd card is making short on the contact of sd card of tablet, try to use recommended micro sd card, firstly try another micro sd card following the instructions in user manual of tablet.
Apr 11, 2014 | Cell Phones
How do I insert the micro sd card into the Nextbook Premium
Good question. And before you brake anything, take a good look at the cover in the back for the SD card.... It is that square port next to the rear webcam. It is hinged at your right-hand side looking at your tablet from the back. Gently pull with your finger nail towards you putting the force to the left side that is where it opens like the port in a telephone. The other side knee it from getting lost and it should close thought even with the micro card inserted.
Jun 14, 2013 | Tablets & eReaders
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Hi Can anyone please tell me how to transfer music from my computer to my viewsonic viewpad 7. Many thanks
put micro sd card into usb with a usb micro sd holder a put music or photos onto it/put micro sd back into viewpad slot next to sim card slot /thats it.
Oct 01, 2011 | ViewSonic ViewPad 7 7Inch Android 22...
I dont know where to insert sim card in lg vu cu920?
Slide the back cover off, remove battery, look for 3 gold dots right above the micro sd text written on the silver colored metal
May 21, 2010 | LG Vu CU920 Cellular Phone
Cell Phones Logo
Top Toshiba Cell Phones Experts
Computer Repairing
Computer Repairing
Andrew Taylor
Andrew Taylor
ka4iup
ka4iup
Are you a Toshiba Cell Phone Expert? Answer questions, earn points and help others
