Question about Whirlpool Refrigerators
I have a side by side Whirlpool refrigerator that will not dispense ice. Ice maker working fine, just will not dispense. We did check the micro switch and it is working. No sound coming from ice maker motor and we even ordered a replacement motor, with no luck. All features on control panel seem to work when pressed. Auger turns when manually done. Any suggestions on what to now check?
    Master:
  • 511 Answers
When u trip sw to dispense motor must run - so does proper voltage appear at motor connector tabs? If not, follow it back to the voltage source. If so, does motor turn when not connected to mechanism? If not, the motor is defective. If so, is the mechanism from the motor to the auger free to turn. IE can u turn the auger from the motor connection?
Posted on Dec 09, 2014
  • Brenda
    Brenda Dec 09, 2014
    We think it may be a connection issue with no power to motor, but cannot determine. Motor makes no sound at all for the old or new motor. We do not have a low voltage tester. When we attempted to test the plug at the bottom of freezer door, we could not get a reading with our tester.
  • Your Consultant Dec 10, 2014
    well, u r going in the right direction. chk out this manual - http://www.google.com/url?sa=t&rct=j&q=&... - it may apply to ur unit or may be close enough to get u there. Make sure crushed/cube sw it fully seated in one direction and lock sw is not on.
Ice will not dispense. Ice maker working and water will dispense.
The micro switch that activates the auger is likely failed.
It is at the top of the fountain lever for ice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 09, 2010 | Whirlpool Centralpark 25.6 Cu. Ft....
Ice maker stopped making ice, it just stopped. There is nothing blocking the outlet, no debris. The water dispenser still works fine but the ice maker is not working. I have a whirlpool 2665 refrigerator....
your ice maker unit is gone bad if you have warenty get them to replace the ice maker if not you need to do it :(
its coast +- 120$ :(
911service today . com
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser won't work
check the freezer door switch; this is a safety so the ice maker wont come on while the door is open
Oct 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker works fine but we can no longer dispense ice from the door. No sound, nothing. Water dispenser works fine though.
There is a micro switch behind the panel above the dispenser lever. It's the switch that the leaver presses on when you push a glass into it to fill with water. Pop the panel off and you will see the little black switch I'm refering to.
Aug 15, 2009 | Whirlpool GD5SHAX Side by Side...
Ice won't dispense, suspect switch in door cover. how to remove door cover to check? Oddly enough, my ice maker stopped working AND the switch in the door (or other circuit problem for dispensing) failed...
Insert a small putty knife between the dispensor plate and the dispensor cover about 1-2 inches from the sides and press down and inwards . Do this carefully because there are 2 plastic "clips" at the bottom . Once bottom is free , lift upwards and the cover will come off . Remove the plug and it's free . There is a white contraption , large , that have 2 rods the micro switches clip onto and sometimes , the switch on the left , has the broken rod holding the micro switch . This causes no ice dispensing .
Aug 15, 2009 | Whirlpool ED2GHEXN Side by Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore side by side
take out ice bin, make sure you get it lined up when put back together, should click,sometimes they are a little off and you have to keep trying, mine has that defect, it works, but only on its terms, its a pain to do, but that can stop it from working due to a safety thing
Oct 30, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
93 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
