Question about HP Office Equipment & Supplies
Hp laserjet 500 mfp m570 printer the magenta cartridge (tried 6)are all miss printing in the left side of page what can it be ?
    Habit-Forming:
  • 91 Answers
Oops , you are right , the opaque glass lenses in front of magenta cartrig try to clean it !
Posted on Dec 09, 2014
The problem is not the toner cartridge, is the laser unit (LSU) for that color. Laser unit have a hexagonal mirror that spins on the motor shaft. Because the motor spins counterclockwise, on the left of each face of the hexagon mirror you will get a gradient deposit of dust. You will have to remove the LSU units and clean the mirrors and lens for all colors. Is not an easy work you know... call a professional service center if you are not a technician. You can search the web for a service manual and get a real help from it.
SOURCE: hp laserjet 2420 printer printing completely black pages
remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
Posted on Apr 05, 2009
SOURCE: STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Posted on Apr 17, 2009
57 varieties
  • 1653 Answers
SOURCE: HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Posted on Aug 29, 2009
SOURCE: HP Laserjet CP1215 printer prints out of alignment
Calibrate the printer. Follow these steps to calibrate the product and align the CPR.
1. Open HP Toolbox
2. In the Toolbox window, click the product model name to expand the menu choices.
3. Click to expand the Device Settings menu.
4. Select Print Quality from the Device Settings menu, and then click Calibrate on the Print Quality panel.
5. Click OK when the Your request has been sent to the device message appears on the computer.
The calibration begins and lasts for approximately 2 to 3 minutes.
If the printout still not acceptable, repeat steps 1 through 5. You can recalibrate the printer as many as three times. If, after three calibration attempts, the printout is still the same, service the product.
Posted on Apr 06, 2010
  • 313 Answers
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Posted on May 07, 2010
Why does the 2550n printer not printing fully in the left column
Is the print quality poor on left side for all colors? You may have one bad cartridge. Create a paint document with Yellow, Magenta and Cyan squares on the left side and see if one color prints better than the others. You can also gently shake the cartridges to redistribute toner.
Sep 08, 2014 | HP Color LaserJet 2550n printer + HP Color...
Hp laserjet only prints clearly on 1/2 the page
YOU PROBLEM IN THE FUSER STAGE MAYBE FUSER FLIM IS PROBLEM
Mar 28, 2013 | HP LaserJet 1200 Printer
HP CM1015 - stil works; Magenta does not print even though full
The magenta might have been freezed, change the magenta.
Thanks.
Jun 19, 2012 | HP LaserJet CM1017 MFP All-In-One Color...
Blank pages
Are you checked cartridge contacts left side of the cartridge bank, you can observe three flexible plastic shells representing the contacts to cartridge,, check them there is the problem....
Jan 30, 2012 | HP LaserJet M3027x MFP Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
My name is John HP 1015 MFP printer will not print Magenta.
This is caused by a dirty laser unit.
It is possible to clean the lenses and mirrors (with care not to scratch the surface silvered mirros AND not to disturb eany of the optical components)
There's quite a bit of dismantling to do to get to the laser unit, but if you work methodically (and remember to double check everything when you are 'rebuilding' the printer) it is certainly possible.
This is a common problem and also appens with HP Color Laserjet 1600, 2600, 2605, CM1017, and Canon LBP5000.
Dec 19, 2009 | HP LaserJet CM1015 All-In-One Printer
Replacing Cartridges on the HP Color Laserjet CM1312nfi
Yes, you will replace the whole cartridge. Open the front door and pull out the cartridge drawer. Grab the handle for the magenta and pull it straight up. There should be directions in the box.
Jan 20, 2009 | HP (Q6473A) Print Cartridge for Color...
37 people viewed this question
Seeker5211
Seeker5211
