Question about Honeywell Ademco Honeywell 5881en Wireless Receiver High Sec
Is the 588ien compatible with a vista 10 panel & can it support the honeywell 5802wxt2 panic pendant ?
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 93 Answers
Depending on the age of the Vista 10, yes, but you'll have to be quite knowledgeable to make the necessary program changes. Be advised that there have been a number of compatibility issues since Honeywell started changing component designs in recent years without changing the part numbers...good luck.
Posted on Jun 14, 2015
I need to replace my Honeywell ademco keypad M6674 Rev A. I have a vista 10 control panel. What model do I replace it with?
I am not familiar with this keypad, but if it were me, I would look to upgrade the control panel to a Vista 20P, although it's a bit involved...which keypad to use as a replacement depends on whether the current unit is wired or wireless. For wired, a 6150 or 6160 is appropriate, wireless perhaps a 5828 would be suitable...you might get a better answer by contacting Honeywell directly.
Jan 23, 2015 | Honeywell Home Security
Can't access installer code honeywell vista 20p
Power down the panel, remove the battery. Hold down the * and # while re-powering the panel. It will jump right into programming. Release the *and # button and proceed with programming.
Apr 07, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
HOW TO CHANGE THE BATTERY IN HONEYWELL ALPHA 6160 KEYPAD
There is no battery in the Honeywell 6160 keypad. It is powered by the transformer in the control panel. If it is showing BAT on the keypad, check the main system battery in the control panel.
Feb 28, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
The sensor Honeywell TC807A 1036 (Smoke Detector), is compatible with a NFS-320 Fire Alarm Control Panel?
I don't know if that particular smoke is compatible or not, but the NFS-320 is a commercial rated UL864 Revision 9 fire panel, which means the documentation is part of the UL listing. This means that in order for a device to be compatible with the system, it must be listed in the Installation Instructions as compatible. I couldn't find any mention of that particular smoke in any of the documentation I found for that alarm panel.
Oct 23, 2012 | Honeywell Tc807a1036 Smoke Fire Detector...
Resolve Error Code: C7 on SuperMicro Server
First check the OS compatibility for you motherboard here:
http://www.supermicro.com/support/faqs/os.cfm
Then, if compatible, check the IDE/SATA setting. Change the hard drive controller settings from IDE to AHCI or vice versa to see if the OS kernel panics on boot. If that does not work, please reply with your OS version and motherboard model.
Apr 12, 2012 | SuperMicro Computers & Internet
The Audio doesn't work I need an Audio driver I have hp pavilion dv2000 with windows 7 operating system
  1. Go here http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=1817074
  2. Select Windows Vista or Windows Vista 64-bit , if you have 64-bit Win 7 (drivers from Vista should work on windwos 7 too)
  3. See Driver - Audio for you drivers
May 09, 2011 | Computers & Internet
When I include any of my DT7500SN into the list of polled devices, my Vista 4140XMPT2 says **** DISARMED **** TEST ZONE then OPEN xx ZONE xx even though the zone is closed. This happens...
*86: On all control panels from 4140-4140XMPT2, Vista-40, and Vista-50, *86 allows a single 4208 to operate as zones 10-17. a. With this field enabled, no other polling loop devices will operate. b. There is a special dip-switch configuration that allows this mode
also: check the loop number of the polling zone is set to 1.
Jun 26, 2017 | Honeywell C & K Honeywell DT7500SN V-Plex...
HP PSC 2350 Printer/Scanner & just purchased a new computer (Windows Vista) & the discs I have for this printer/scanner only support Windows 2000, XP not Vista.
You can set compatability to windows 2000. I presume you have vista. start menu. control panel, programs... then you will see set compatability or similiar (my control panel won't open at the moment). use the wizard to walk you thru the steps. select the program you are having issues with. It will allow you to run the program as win 2000 compatability.
Robert
Aug 27, 2008 | HP Office Equipment & Supplies
Honeywell Ademco Honeywell 5881en Wireless Receiver High Sec Logo
83 people viewed this question
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
