Cars & Trucks Logo
Anonymous Posted on Dec 09, 2014
Location of body contol senser on a 97buick century limited
Jeff Armer
Level 3:
  • Cars & Trucks Master 15,575 Answers
  • Posted on Dec 09, 2014
Jeff Armer
Level 3:
Answers
15575
Questions
Helped
7100566
Points
73899
Do you Body Control Module ? It's below left side of instrument panel . What type of problem are you having ? You can not change a BCM for another one
Important:
• Read the BCM set-up procedures carefully and completely.
• The BCM will not function properly if the Setup New BCM Procedure is not performed.
• Perform the Theft Deterrent Re-Learn procedure after successfully finishing the Setup New BCM Procedure. If the Theft Deterrent Re-Learn procedure is not performed after a BCM replacement, the following conditions may occur:
- The vehicle will not be protected against theft by the PASS-Key® II system.
- The engine will not start !!!!!!
What does PCM mean and where would it be located on a 97Buick Regal 3800 supercharge i have wire hanging down with piece melted on it that says pcm
P=Powertrain
C= Control
M=Module
Located right front passenger area behind dash in bracket with the BCM. Body Control Module.
1helpful
2answers
Where is the thermostat located in my 1999 buick century 3.1
Follow the upper hose to the motor. Where the hose connects to the motor is where you will find your thermostat.
As the Christmas is coming, every week careucar has 10 items special offer for you, such as Volvo VIDA DICE, Super VAG K+CAN Plus 2.0, FGTech Galletto 2, Autel MaxiDAS DS708, NEXIQ 125032, New GM Tech2 and so on. Only one week limited from 1st to 9st Dec.
#1 co2 senser
on the back side of the eng. on top of the exhaust pipe
Need to find location of fuel pump relay on 1987 century limited 2.5
fuel pump relay located on the upper right side of the engine cowl.
3helpful
Need to know were the MAP SENSOR is located on the a 97' nissan king cab 2.4L
Doesn't have one it does have a mass airflow senser and it's in the air intake hose on top of the air filter box. If the hose to the throttle body leaks in any kind of way ( attached hoses off or leaking cracked hose your gat Map codes the the airflow senser isn't getting full flow and theirs a problem that needs corrected check everything before changing the senser though as it's expensive and the senser is'nt returnable if your wrong.
2helpful
Trouble code P0140 0/2 2002 buick certury v6 3.1L What needs to be fixed
No actitivaty at the O/2 senser. It can be it's just unplugged the wire is bad a fuse is blown and or the senser is bad. their are more than one senser so check them all
2helpful
2answers
97buick park ave dontstart battery is brand news
Sounds like your starter or the starter solenoid has gone bad
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
2helpful
2001 Buick Century shift solenoid
It is in the side cover on the valve body. The transmission needs to be removed to access the solenoids.
2helpful
Cannot find a themo senser on the aircon cooler?
most air temp sensors are now very small and located in the air pickup stage of ac
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
