Question about Canon PIXMA MP540 All-In-One InkJet Printer
How do I clear a B200 error. I have turned printer of but error is still there
Turned it on and of so cartridges centre themselves. Paper is loaded in bottom tray but error is still there
  • 21 Answers
The printer is no longer any good. I called cannon and they advised me that it was not repairable. they did offer a discount on a new printer. Hope this helps.
Posted on Dec 12, 2014
WHAT TO DO WHEN I HAVE AN ERROR CODE B200. i CANNOT PRINT AS THE MESSAGE IS CONTACT YOUR SERVICE PROVIDER. IS THERE A WAY I CAN FIX IT MYSELF////
Hi Kathleen,
to clear the Canon B200 error code:
Steps for 4+ Cartridge Printers
  1. Remove All Cartridges. Do whatever is necessary to remove the individual ink cartridges from your printer. In most cases this will be opening the lid of your printer and waiting for the cartridge cradle to move into the correct position.
  2. Remove the Printhead. This is easily achieved in most printers by simply lifting the orange/gray locking lever on the side of the cartridge cradle and then gently lifting the printhead from the printer.
  3. Reinstall the Printhead. Gently put the printhead back into your Canon Pixma printer and lock it into position firmly.
  4. Reinstall All Cartridges. Place all of the cartridges back into the printer and close any open doors. This makes sure that your printer is actively examining the reinstalled cartridges and printhead.
  5. Unplug the Printer. Physically remove your printers plug from the wall and leave it unplugged for 5+ minutes. This allows the printhead to cool and all residual electricity to leave the printer.
  6. Plug the Printer Back.
  7. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
Steps for 2 Cartridge Printers
  1. Turn the Printer off. When your printer is in this error state it will not let the cartridge cradle within the printer move. However resetting the printer should clear the error message temporarily allowing us to troubleshoot further.
  2. Turn the Printer Back on Again.
  3. Remove the Problem Cartridge. Whilst the Canon Pixma error messages do not tend to specify which cartridge is causing the problem, you should be able to have a rough idea based upon which cartridge was last replaced.
  4. Install a Replacement Cartridge. As the printhead is part of the cartridge, sadly there is no way to stop the B200 error without replacing the cartridge. I would recommend either installing a new cartridge or a previously used cartridge that you know to be functional.
  5. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
  6. If Necessary Replace the Other Cartridge. If the error persists with the new cartridge, it may be that the other cartridge has developed a fault and is the cause of the B200 support code. If at this point the error remians I can only recommend replacing the other cartridge.
Aug 11, 2017 | The Office Equipment & Supplies
I have an error message B200
Hi Kathleen,
Aug 11, 2017 | Office Equipment & Supplies
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
Why the cartridge does not move when the printer is on. and when i set to print error no. B200 appear?
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#b200
B200 Error- This could also be displayed as P10 or the orange and green light blinking 10 times Description:
B200 is a service error that can occur due to a hardware failure with either the printer or the print head.
Resolution:
In most instances, a B200 error will require a repair at a Canon authorised repair centre, however prior to sending your printer for repair please follow the steps below to try and resolve this error-
  1. Turn off the printer
  2. Disconnect the power cable
  3. Open the printer cover
  4. Check for any orange protective tape or white polystyrene and remove if necessary
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary
  6. Close the cover
  7. Reconnect and turn on
If the error message is still showing, then it is necessary to deliver or send the printer to an authorised repair centre.
If the printer is still under warranty, (generally one year from purchase) and supporting documentation is provided, then a free of charge warranty repair will be carried out.
If the warranty has expired, then any repairs can only be carried out at cost and charges will apply.
You can find the details of your nearest repair centre using our interactive repair centre locator.
If you own a PIXMA PRO-1 please contact us directly as you may be eligible for an on-site repair.
Jan 14, 2016 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Service error B200. camcel printing and turn
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Feb 08, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Canon pixma MP480 printer error code B200. What is B200?
Apr 07, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Error Code B200
Nov 17, 2008 | Canon PIXMA MX850 Multifunction Printer
ERROR LITE....
I loaded a refilled cartridge that had a faulty chip on it, and the printer would not read that the cartridge had been loaded. I don't know if there's anyway to check the chip yourself, but our cartridge refill center replaced it and we were running again.
Aug 21, 2008 | Konica Minolta magicolor 2400 Laser...
Error Code B200 on Canon Pixma IP4300
Just restart the system and turn off the printer and turn on the printer it will work.
Check did you correctly placed your cartidges.
Mar 03, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA MP540 All-In-One InkJet Printer Logo
203 people viewed this question
old marine
old marine
