Question about Kitchen Appliances - Others
Have a scottsmanc1448 ice machine shows codes 1 an an 2 longharvest cleaned all water sensors descaled machine works threw all cycles water flows over both curtain coils makes no ice goes threw 3 cycles shuts off water s there compressors on pump runwater at a good flow put 2 new curtainswitches abot a month ago lights shows curtains r working harvest asssist selonoids r retracting there not stuck hot gas light comes on right before harvest cycle can yo help me figure this machine out
    Master:
  • 379 Answers
Ok, what you have not told me was the temp of the ice plate. If you have an inferred thermometer now is a good time to use it. what is the Temp of the plates or ice collection try. Ice will never collect if it is not below zero C. 32F my guess is it must be below 28F. you need some kind to thermometer.
Posted on Dec 12, 2014
Error code 5 on saeco minuto coffee machine
Error code 5 means the water flow is obstructed. Here are possible locations:
1- The machine was not descaled. Calcium deposits are clogging the water system.
2- The flow meter is not passing impulses for water flow speed & quantity.
3- Descale Descale Descale.
Before you select the automatic descaling, make a few espresso without adding coffee grounds. The automatic cycle does not clean the coffee side of the machine. You have to do it intentionally.
Dec 18, 2016 | Saeco Coffee Makers & Espresso Machines
How is descaling done
Fill the tank with vinagar and run the machine to empty the tank restart the process for couple of cups live the machine over night run clean water threw the machine you done.
Aug 19, 2014 | Keurig Elite B40 Coffee Maker
Short freeze
Ice is to thin. Check to make sure water inlet valve is not letting water go through valve during freeze cycle. Make sure condenser coil is clean and condenser fan is running. Check the hot gas valve to make sure it is not bypassing during freeze cycle.
Apr 15, 2014 | Scotsman C0630MR_HD30B-32 684 lb 30"...
Scotsman ice machine is not making ice goes through the motions but no ice
h=harvest 2=harvest problem 8=makes ice to fast 0=off.most common issue is your senors/ice mach needs to be descaled and clean
Feb 25, 2014 | Kitchen Appliances - Others
Starts into ice making then dumps ice slurry in tray
Adjust the ice thickness sensor out 1/4 turn at a time until 3mm ice bridge forms between cubes. Clean condenser thoroughly, descale ansd sanitise waterways inside.
Jan 30, 2014 | Manitowoc QY-0214A Self Contained Ice...
Bin full light stays on
You need to pull the bin full sensors and clean or replace them. Pull the front cover off remove the ice deflector you will see the water sump tray pull the ice deflector grate out of sump. Now where the ice fall into the bin on the right and left side in the shout there is 2 sensors they will pull out sideways, they will both have a wire ran to them pull wire and sensor up to where you can see the red sensors om them take a descale solution Scotsman brand mix per instructions and clean the eyes now would be a good time to clean and disinfect the whole machine. Install them back and start machine if this dose not clear the bin full light then replace them.
Jan 16, 2014 | Scotsman Cooled Modular Contour Cuber...
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
The scotsmand machine make ice, but quantity of the ice seems limited. The machine was descaled a month ago, no signs it needs serviced again. Could the cube sensor be faulty?
Take a can of compressed air and blow out the dust in the coil. If the coil can't get rid of the heat, it reflects in the amount of ice it produces.
Sep 15, 2010 | Scotsman Ice Machine, Cuber, 1825 lb....
Ice machine is not working after it was unpluged
check make sure water is turn on.
bin sensor stat might be open.
lastly on p.c.b board there is a rest button.
make sure ice thickness sensor is descaled and petrolueum
jelly smeared terminals of prons( if it a casade type)
Feb 21, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Kitchen Appliances - Others Logo
53 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
