Question about GE Spectra JBP78 Electric Kitchen Range
Where can I get a replacement oven door for my electric glass top kitchen range?
How to replace a glass top on my stove?
To lift up cooktop open oven door. Remove 3-4 screws securing cooktop to top of oven. lift up. Top hinges back. The rest is plain to see. Good luck. Will help futher if needed.
Mar 30, 2011 | Frigidaire FEF366 Electric Kitchen Range
The glass broke need to replace it.
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Feb 03, 2011 | GE Spectra JBP78 Electric Kitchen Range
Front door glass on oven shattered. Is it still operational?
Technically yes, but safely... NO!!
Here is a tip that I wrote about the oven door glassreplacement...
heatman101
Nov 24, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Glass top on range is broken.
pull bottom panel out look on stove middle just below oven door
thumbs up
Aug 17, 2009 | GE Spectra JBP78 Electric Kitchen Range
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Broken inside glass door on my electric KitcherAid glass top range
sounds like you may have thermal breakage. does your oven have the self-clean option? you can have the glass replaced easily. i wouldn't use the self-clean option for now.
Aug 02, 2008 | KitchenAid KGST307 Gas Kitchen Range
Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
