Question about Canon Office Equipment & Supplies
Canon IRC4080i. Copy function has gone from display after moving machine so I can print but not copy
  • 92 Answers
SOURCE: Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Posted on Dec 30, 2008
antiochpc
  • 1314 Answers
SOURCE: CAN'T PRINT A "REPRINT.......ANY RECEIPT"
You're welcome. Please come back and give this answer a rating of fixya. Good day :c)
Posted on Feb 16, 2009
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Bonni
Posted on Feb 26, 2009
  • 32 Answers
SOURCE: Functional Problem SC321-00
the sc320 code would indicate that the polygon motor should be replaced. when you turn on the machine, the normal high pitch buzz will not be there the motor is not spinning up. that's the reason for the blank copies.
the sc321 code is a "no laser writing signal (f-gate) error". which would caused by the polygon motor not spinning.
replace the polygon motor.
Posted on Apr 03, 2009
  • 5 Answers
SOURCE: Canon 3200 only prints one copy from computer
You will probably have to delete and reinstall the printer. I have had features quit working on my 3200 and on my 2 105's. A work-around is to print to your mailbox and then print your job from there.
I tend to have problems from Microsoft products more than adobe.
Are you printing through a fiery or just through the print board on your copier. If you are using a fiery, then you can resend the job from the command work station (a free download if you are using the fiery).
Posted on Jun 22, 2009
Copy Machine is running ready but can't print and copy.
The paper tray is not placed properly leading to erroneous sensing place the paper trays properly
Jun 22, 2015 | Canon ImageRunner 4570 | IR4570 |
Canon MP110 running Windows 7 with corret software will not print colour nor will it read colour in scan.
Can you try to do COPY function?
If COPY function fail,means the machine in fault. Most probably is PRINT HEAD in fault.
Nov 24, 2014 | Canon Office Equipment & Supplies
Printer will not print or copy even though head cleaning and alignment suggest it can print
Assuming that you have tried all the trubleshooting sugestions in the
book and on line..? try and contact you local Canon customer helpline
they usualy have an expert handy who can guide you through the
more difficult programes,it's worth a try and it's free...goodluck T.C.
Mar 31, 2013 | Canon Pixma MP990 InkJet Printer
Is there a way to find out the total copy count for the printer?
You can get the copy count for the MF6550 by using the following procedure:
- Press Additional Functions
- Press 2
- Press 8
- Press Additional Functions again.
- Scroll down through the options. There will be an option for Counter -- select it and the copy count will be displayed on the screen.
For page count and configuration page instructions on other copiers, printers, and fax machines, visit the How to Print Configuration Pages website.
Jun 15, 2011 | Canon imageCLASS MF6550 Monochrome Laser...
Canon_fax_b820_error_342
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If your problem not solved replace the SCNT PCB
May 01, 2011 | Canon FAX-B820 Plain Paper Bubblejet
Mi da errore ##331 .... dopo aver cambiato le cartucce . prima mi dava errore ##342 ... e non mi prende la carta . ho il fax canon b 140 AIUTATEMI Grazie mille
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If problem not solved replace SCNT PCB.
May 01, 2011 | Canon FAX-B840 Plain Paper Bubblejet
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
We have a canon imageCLASS 2220 coper/fax that is set to default to fax when the power is turned on or the machine is idle for a few minutes. How can we get this default changed to copy instead of FAX?
I need to change the IP address on my canon imageclass 2220. I have moved locations and I know they are preset on the machine HELP I know I am overlooking something
Jan 18, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Testing print cartridge
Printing is not possible with B-820. You can just make a copy of an original print. Put the original in the mentioned place, it displays 'Document Ready' then just press 'START' button twice. you'll get a copy.
Aug 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
32 people viewed this question
old marine
old marine
