Question about Home
My triton T90xr doesnt heat the water as well as it used to. At max the water is warm. No problem with pressure
    Problem Solver:
  • 8 Answers
The heater coil is tired. A replacement should be around £50 plus labour. So not cheap
Posted on Dec 23, 2014
2 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: I have a triton T90xr the water is only luke warm
your incoming cold water pressure may have to be reduced if not by the main control valve a pressure reducing valve may have to be fitted
Posted on Sep 18, 2009
My Triton shower Eco Excite 8.5kW keeps tripping fuse when turned on !!
Could be a pump jam, do you have hard water ? Could be scale build up.
Is the shower head blocked ? Unscrew just the head (leaving the hose line attached to shower) and try again. If that is the blockage, then clean it with descaler.
Also check you have a good pressure on your water supply going in the Triton. Low pressure can set off safety switches. Again, check for blockages.
Check also for breaks in wiring and check there is no water ingress at any and all connections.
Is it an old unit ? Is it serviced regularly ? .......finally....
are all the settings set to MAX ? if so then use lowest setting first.
If it works then move settings up gradually until it trips.
Any filters need to be checked if possible.
Good luck Red.
Jul 16, 2016 | Home
I have a problem with my triton shower.i use this shower for 9 months everything was ok but now to get warm water I have to turn the dial to 9 or 10 and it just a little warm and the pressure is very...
Since I am unsure of the model you are using I would suggest you go to their site and check the FAQ's and support information. You can select your info in the drop down boxes and go from there:
FAQ Triton Showers for the Homeowner
I hope this helps.
Jan 29, 2015 | Home
I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Nov 11, 2009 | Water Pik Waterpik& Elements& Fixed Mount...
I have a triton T90xr the water is only luke warm i have changed the element and its still the same
Sep 16, 2009 | Shower Spa Home
The unit will not heat any water, press hot but goes straight to
probley heater eliment ? if not megga dear unit buy new one probly cheaper as long as u fit ure self
May 10, 2009 | Home
Triton t90i shower doesn't heat water and lacks power.its about 5yrs old and is used every day
it is temp contrl shower and you could have to take out the cartdrige and change it,, probly clogged and it's not letting the hot water be hot enough, if the pressure is good then the cartridge is bad
Apr 20, 2009 | Water Heaters
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
64 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
