Question about Crosley 0187SST Turntable
Can you plug in crosley turntables to a bose speaker system to increase the sound quality? Do you need an amp or is it all included?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Crosley Master
  • 924 Answers
No, you cannot. Your Crosley will not have the correct line output jacks. Even if it did, although the output level will be fine, you will not have the proper RIAA equalization, making the sound worse, not better.
Posted on Dec 11, 2014
4 Suggested Answers
  • 157 Answers
SOURCE: Crosley traveler turntable noise
Hello attaboy. You may need to check you ac cord if the noise is in turntable, radio, & cassettte mod. If it has a 3 prong plug than you are missing a GND connection, in the cord or inside the unit. If it has a 2 prong plug than take it back or open it up and replace filter capacitors or bridge rectifiers in units power supply.
Posted on Sep 19, 2008
freetek
  • 5568 Answers
SOURCE: new crosley CR249-GR "wow and flutter"
I see your message isn't new anymore but Crosley does have a website with warranty and support info:
Crosley Radio
Posted on Aug 15, 2009
waynescot472
SOURCE: Sound quality is terrible on my Crosley CR79
They are just crappy turntables-low volume and thin tinny sound
Posted on Jan 17, 2013
When I plug in my marantz TT-42 turntable to my Yamaha R-S300 receiver's phono input, I get a muddy and loud sound. I've tested the turntable with direct input to Bose speakers and it works fine.
If the turntable produces good sound with a line level input on another system, you have the turntable with the pre amp built in. That is why the sound is loud and distorted.
Mar 05, 2017 | Yamaha Audio Players & Recorders
I got a crosley recently and it has been working great up until now. Whenever I play a song on the record everything works great it is just the sound. its horrible. I think it has something to do with the...
The Needle may need replacing, if after replacing the needle and you have the same problem, it could be a connection from the needle pick up to the recever.
Feb 09, 2014 | Crosley CR249TA Turntable
Speakers are low, even with the volume turned all the way up
Please check that the amp has a Magnetic Cartridge Pre-amp built in. If it doesn't you need to buy one.
Dec 27, 2012 | Crosley 0187SST Turntable
I would like to add a turntable to my Bose Cinemate II but when i plug the RCA directly into the Bose module the volume has to be to the max and is still very quiet
You need a preamp to solve that problem, the older amps and receivers had built in phono inputs with a preamp stage. Radio Shack use to make a preamp that ran on a 9volt battery for turntables that ran into the very problem you are talking about. But I do not know if they are still available, go to www.ebay.com Type: turntable or turntable preamp
Apr 07, 2012 | Bose Cinemate Digital Home Theater System...
My crossly turntable isn't level. Sound quality is poor as a result. Any ideas? Thanks in advance.
Hello, my Crosley has the exact same problem. I'm struggling to find any answers at the moment. Did you manage to get yours fixed?!
Dec 22, 2011 | Crosley CR249TA Turntable
Does my turntable need a new cartridge? I have a Technics SL DD22 which hasn't been used in a while. I hooked it up to a Bose receiver which works fine (hooked up an i pod to it before) & it plays...
The output from any regular turntable is far too low for most amplifiers to handle. You need to either run the output through a pre-amplifier first to bring the signal up to line output levels suitable for most recording devices and amplifiers or run it into an integrated amplifier which includes the pre-amp stage.
If your Bose receiver specifically includes a turntable input then it has a pre-amp built in, but as so few folks use turntables any more very few devices have the correct input. Pre-amps are still easy to obtain and can be very cheap, but cheap ones produce a noisy and unpleasant output which is magnified by the amplifier. If ever there's a choice to be made, spend the money on the pre-amp and go budget on the main amp.
I hope that I've saved you wasting money on something you didn't need. Please take a moment to rate my free answer.
Sep 24, 2010 | American Audio Vinyl 101 Direct-Drive...
Sound quality is terrible on my Crosley CR79 turntable. Sounds very tinny and terrible. Got a new needle and the problem still exists.
This could be an earth lead to the cartridge problem, or the cartridge itself. Check the connections.
Feb 07, 2010 | Crosley 0187SST Turntable
Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Jul 28, 2009 | Bose Lifestyle 38 System
Adding turntable to bose music wave system
Hiya, sad to say it wont work even with the correct plugs. If you really need/want to get it going, you will need a RIIA pre amp to use to convert the turntable levels to an acceptable level for the bose. Once you have that, then get the correct matching plugs for the bose (sames guys that supply the preamp should be able to help). Suggest a google search in your area "RIIA PREAMP" and see who supplys.
Best of luck
Jul 15, 2009 | Bose Wave Music System CD Shelf System
Crosley 0187SST Turntable Logo
121 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
