Question about Kenwood Car Audio & Video
My Kenwood D-R350 CD player will only play 3 out of the five discs loaded. It skips one and message displays "no disc" in the other.Any suggestions would be much appreciated.
Nothing
  • 1,253 Answers
Either the laser sled assembly or the platter/turntable encoder. Both are costly to repair and/or find replacement parts for.
Posted on Dec 09, 2014
Testimonial: "Many thanks, this was most helpful. I might be able to source these parts from a second non working unit I have."
robotek
  • 1512 Answers
SOURCE: toc error
toc error means "table of contents" error... means the player is unable to read the disc at all. May have a dirty focal lense to laser. clean gently with some windex on a cotton wool bud. It may be a faulty spindle motor that spins the disc. the bearings get worn or uneven and do not allow for disc reading to be successful. a check for this is a drop of oil to the bearing. It may then start to read discs, but will still require the motor to be replaced. . Check for the above... but if there is more required, take it to a Kenwood 'Agent... it may need a laser change
Posted on Dec 15, 2007
SOURCE: protect feature on kenwood car cd player
I AM ARGENTINIAN THIS WAS THE SOLUTION. THANK CABEZA DE GATO
Posted on Nov 25, 2007
SOURCE: Kenwood in dash cd player
The protection function is activated when the speaker wire has a short-circuit or touches the chassis of the vehicle. Wire or insulate the speaker cable properly and press the reset button. (The reset button is that little pinhole button below and to the right of the volume control). If you do this and the "PROTECT" code doesn't disappear, you'll have to consult a service center. Further, if you had this professionally installed, they should be obligated to fix the issue for you (hopefully).
Posted on Aug 08, 2007
SOURCE: Kenwood KDC-2025 won't play CDs
hey it does not play mp3 discs. u need a regular disc. mathews
Posted on Apr 04, 2008
tech48
  • 624 Answers
SOURCE: Alpine CDA 7878R - Hi Temp - won't play disc
Does it play the tuner but not the CD?
If it so, the problem is directly related to the CD deck. If not, the problem could be a sensor or any number of other components that may have overheated.
Try to reset the unit. Most of the time this error is an electrical problem not fixable by the end user. But it is worth trying to reset the microprocessor and see if that helps.
Here is a diagram of where the reset button is at. Press it in with the tip of an ink pen or paperclick, whatever you have that will fit into the little hole. Just hold it in a couple of seconds. Be advised that when yo reset the unit, you will loose all things in memory like the correct time, preset radio stations ect.
If this does not help you will need to have it checked out by a good repair center. These Alpine radios are very good radios and are worth getting fixed unless the estimate is close to what you paid for it.
good luck, I hope this helps. if so, a good rating would really be appreciated. You can always ask me for more help if you need it. I have been repairing car and home audio equipment for over 17 years.
Posted on Jun 21, 2008
I have a kenwood multiple cd player dr350 and it won't play cds
Kenwood multiple cd player dr350 draw and cd player has stopped working draw is stuck in and cd player does not work and the skip disc doesn't go round either.
Sep 21, 2013 | Audio Players & Recorders
My kenwood D R350 CD player keeps skipping on some but not all tracks. I have tried to CD cleaner but this didnt work, what can you advise
The problem is in the laser pickup assembly, overtime the laser becomes weaker until it can not track properly resulting in skipping and eventually not been able to read the disc. My next step would be to get a CD cleaning kit which you have already done. The only option is replace the assembly which is not cost effective, but far cheaper to buy a new CD player.
Mar 20, 2011 | Audio Players & Recorders
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
CD player of a COMPACT DISC STEREO SYSTEM fails to operate.
There are a couple of questions that need to be answered in order for me to get an idea of the problem and its solution.
1) What is the make and model please?
2) When you load the discs, do you hear them load up one at a time without them actually playing?
3) Is there an indication on the front stating "no disc" or any other message?
Thanks,
Dan
Jan 05, 2009 | Audio Players & Recorders
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
CD Player not working
i have an older machien here its a mini hifi system fw 540c it wont play any cd's i put into it it skips tru all 3 trays and than says no disc or disc not finilised. i had it in storage for about 4 months over a winter worked fime b4 can some one tell me what could help before i trow it away (>-_-)> ty<(-_-<)
Mar 04, 2008 | Teac GF-350 CD Shelf System
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
Car Audio & Video Logo
80 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
