Question about Bosch Exxcel WFO 2864 Front Load Washer
I have a bosh EXXCEL and model number is WFO2864GB. The machine works just fines at the start the first step works fine but doesn't move on to the next step which ch is washing or rinsing if I
    Problem Solver:
  • 17 Answers
Control module or sensor
Posted on Dec 09, 2014
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Husqvarna 3610 doesn't pick up lower thread
Hi, Check to see if needle is bent. If the needle is bent it will not work well and soon it will break.
Replace the needle. Also lube the moving parts on your machine. (fine oil) sold in most sewing centers.
Jul 24, 2011 | Husqvarna Viking 1
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Recently purchased a new Uniden Corless Phone & answering machine. It wont wring or go through to the answering machine. It is working, if you call from a mobile & answer it, line is OK. Had...
What is the product code?
Finding the product name/model number. transpix.gif
Finding the product name/model number:
  1. Look on the bottom of your phone for the serial number sticker.
    (If you have a multi-handset unit, it will be on the main base.)
  2. The product name is in the top left corner of the sticker, above the bar code:
Honestly, i know your hate this response but read through the instructions and re-wire it by what the instructions say. Step by step. if you dont have the manual...respond back and i can send that to you.
May 09, 2011 | Uniden Cordless Phone
My bosh exxcel disher dose dot fill
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Dishwashers
Dishwasher pumps water in and out, but does not wash
Try tilting the machine back 45 degrees for one minute 7 then try one of the programmes. Serousely outr Bosch diswasher was firstly not draining water then not taking in water & another forum suggested this odd manouvre & all is fine now
Nov 06, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Exxcel WFO 2864 Front Load Washer Logo
62 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
