Question about Philips HTL2101A/F7 40 Watts Sound Bar
What cable do I need between my hitatchi tv and philips soundbar
Nothing
    Problem Solver:
  • 11 Answers
You'll need a set of Red/White RCA cables.
Posted on Dec 15, 2015
2 Suggested Answers
SOURCE: philips HTS8100 owner. Have
Same problem with my HTS8100. Little-to-no sound. Sometimes sound comes on very intermittently. I downloaded the software patch from the Philips website and installed it. This fixed the sound problem for about a week, then the problem came back. I'm not sure what else to do.
Posted on Jan 21, 2011
No sound via philips soundbar hts8100 with philips 52pfl7403d tv
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Sep 09, 2016 | Philips Televison & Video
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
Jan 07, 2015 | Philips HTL2101A/F7 Soundbar 40 Watts
Connect Sound Bar to TV (flatscreen - Proscan)
How about fiber optic cable or composite cables. I usually recommemd that people do either of these.
Jun 04, 2014 | Proscan Televison & Video
Proscan how to
I have a Proscan Flat Screen TV Model PLEDV2845A. I want to connect my Philips HTL2101A Sound Bar.
I have intially connected both via Coax cable as the soundbar does NOT have HDMI port. I then went into the setup on the TV to Sound, set sound to PCM
Initially it worked fine. 2nd day it will not won't work. Per instructions from Philips I have upgraded the firmware on the SoundBar.
Any ideas
Jan 06, 2014 | Proscan Televison & Video
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
Soundbar wont work
It basically has an Optical input, or a coaxial input. Use whichever input is available for you from your TV digital output, to the soundbar. If it still doesn't work, the soundbar is probably damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 27, 2013 | Philips CSS2123B/F7 SoundBar Home Cinema
Philips HTS8100 owner. Have ben using the soundbar since Decembr 2007 with no issues. it is intgrated with a sony bravia tv. tried to turn on sound (tv input) and have very limited sound. Turned up to...
Dec 22, 2010 | Philips SoundBar DVD Home Theater with...
My soundbar (Phillips hts8100) freezes on low pwr standby.
hi
i have also same problem, by that time i am pressing tv/ disc button then it should be okay
Oct 11, 2009 | Philips SoundBar DVD Home Theater with...
Philips HTL2101A/F7 40 Watts Sound Bar Logo
119 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
