Question about Garden
Noma snowblower transmission is backwards, put in forward it goes backwards and so on
    Sergeant:
  • 213 Answers
Dear Richard,
Your direction with the gears appears to be 180 degrees out. You may also consider flipping the entire shaft assembly. You. Knowing this assembly is put together correctly.
At this you tube link you will find information to watch for your Norma. The side bar with a catolgue has your answers.
Here is a forum and a blog that may help when the order is corrected
Small Engines Lawn Mowers etc Noma Murray Snowblower question
Craftsman Murray Snow Blower Belt and Friction Wheel Replacement
Posted on Dec 14, 2014
  • 98 Answers
SOURCE: transmission will not shift gears
Vacume line is off --broke going to the trans. the valve that it go's to could be bad. Not hard to replace. That's what it sounds like.
Ken
Posted on Sep 23, 2009
  • 3 Answers
SOURCE: bmw z3 passenger seat goes forward backwards but
It can also be theseat motor since there is seperate motors for up/down & forward/backwards. You can test the switch to see if you are getting power to the connector on the motor by using a multimeter.
If there is power to the motor, I would remove the motor and give it a tap on the ground. Alot of the time the motor is fine, and the tap will free it up again. If it doesn't work you may be up for a new seat motor. Giving mine a tap solved the issue with mine.
Posted on Nov 05, 2009
  • 1374 Answers
SOURCE: 2003 Taurus: my transmission just went out. wouldnt go forward ...
Sounds like a worn out put shaft. Its time for a transmission rebuild. Keep in mind that the stator inside of the Torque Converter is made out of plastic.
Posted on May 18, 2010
SOURCE: Transmission will not go into park
Dear Louis,
I would seem to me that the linkage which goes into the transmission from the shift lever on the steering wheel or on the side of the transmission itself, is not engaging. I doubt is is the transmission, but I am not an expert. You will probably have to take the vehicle to a garage, sot a service station. Hope this helps. Ken from N.H.
Posted on Aug 06, 2012
  • 34 Answers
SOURCE: transmission not move forward backward
Probably. There may be a solenoid not working which is keeping the transmission from engaging the forward gear train but for it not to work at all is unusual.
Posted on May 13, 2013
Norma, 10hp, 29" snowblower, forward gears not working, reverse gears work fine, any suggestions
if its a NOMA THEN ITS AN OLDER MACHINE
check the bearings on axle shaft
worn bearings cause friction drive wheel to lose contact with drive plate
Feb 19, 2015 | Cars & Trucks
My old Jacobsen Imperial 26 only goes a few feet and the drive stops. I put it in reverse to break the locked wheels free. It will then go forward for a few feet, then I have to repeat this procedure
Sounds like you may have too much slack in the drive Chain. Pull the bottom cover off and look. Usually there is a way to move the shafts to tighten the chain.
Feb 06, 2015 | Garden
How to set date and day on INVICTA SUBAQUA NOMA III
Pull the stem out 2 clicks sets the time, pull the stem out just 1 click
turn it forward sets the day and turning the stem backwards sets the
date. I hope this helps
Jul 12, 2014 | Invicta Subaqua Noma Iii S
Snowblower wont engage forward or reverse
Howdie ther is Clutch under the bottom of it that needs to be replaced take the cover off and you will see it
Jan 30, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Transmission not move forward backward
May 12, 2013 | Plymouth Grand Voyager Cars & Trucks
Hi, I have a Noma Lawn tractor and the hydrostatic transmission seems to be slipping, can you tell me how to troubleshoot the problem. Thanks Larry
this isn't a solution but a question...not sure what i should put in there...trany fluid or oil....i was cutting the grass and it stopped going forward or backwards
Jun 26, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Garden Logo
123 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
