Question about Cell Phones
I have a problem with my galaxy note3,i did factory reset and then rebooting system,just the galaxynote3 appears on the screen ,nothing change again
  • 20 Answers
  • Remove the battery and the SD card.
  • Put the battery back in and turn on the device.
  • Try Menu > Settings > Wi-Fi > Menu > Advanced and uncheck Always allow scanning.
  • Now you should be able to turn the device off and reinsert the SD card.
  • Boot it up and your problem might be gone.
    • Also try this if the above mentioned doesnt work
    • You could remove the SD card, backup the data, put it back in the phone and try reformatting it via Settings > Storage > Format SD card .
    • If it's stuck in a boot loop and you can't get in to the main menu, you could factory reset the Galaxy Note 3 using the hardware buttons (but you will lose all data on it). Back up first if you can, and then:
    1. Turn off the device.
    2. Press and hold the Volume up, Home, and Power buttons.
    3. When you see the Galaxy Note 3 logo, let go of Power.
    4. When you see the Android System Recovery screen let go of Volume up and Home.
    5. Press Volume down to highlight wipe data / factory reset.
    6. Press Power to select it.
    7. Press Volume down to highlight delete all user data.
    8. Press Power to select it and wait until it's done.
    9. Highlight reboot system now and select it with Power and your device will reboot.
    Read more: http://www.digitaltrends.com/mobile/galaxy-note-3-problems/9/#ixzz3LPBRtSme
    Follow us: @digitaltrends on Twitter ' digitaltrendsftw on Facebook
    Read more: http://www.digitaltrends.com/mobile/galaxy-note-3-problems/9/#ixzz3LPBHTGRq
    Posted on Dec 09, 2014
    Too many pattern attempt on my galaxy s, I purchased this phone for my daughter and she forgot her password. I am trying to bypass this if possible.
    Note : all data will be lost
    Simultaneously press and hold the power button + volume up button + home key until the Samsung logo appears, then release only the power button. Release the volume up button and home key when the recovery screen appears.
    From the Android system recovery screen, select wipe data/factory reset.
    Note Utilize the volume up/down keys to highlight and the power button to select.
    Select Yes -- delete all user data.
    Note Allow several seconds for the factory data reset to complete.
    Select reboot system now.
    Note Allow several minutes for the reboot process to complete.
    Sep 05, 2017 | Galaxy Cell Phones
    Galaxy s4 never had a active phone line only wifi, I changed the password on the lock screen n can't remember what it is. How or what can I do to get into the fone? Short of doing a factory reset.
    Factory reset is your only option, by design. If you would like to do that, see below:
    Turn the phone off.
    Press and hold VOLUME UP and Home (middle) button
    Press Power until the phone vibrate
    Wait until you see the Android logo then release all the buttons.
    Select Wipe data/Factory reset with VOLUME DOWN, press Power (right hand-side)
    Select YES -- delete all user data with VOLUME DOWN and then press Power
    After format, press Power again to reboot phone. (select reboot system now)
    Dec 26, 2016 | Galaxy Cell Phones
    My samsung t210 is not resetting i have tried button and inside setting options both look like its working but when reboots no change the accounts come back aswell
    Before performing the Hard Reset:
    - In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
    - But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
    Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
    - Turn your Galaxy Tab 3 off.
    - Take out any existed SIM or memory card.
    - Wait for 10 seconds.
    - Press and hold the Volume Up key + Home key, Then press the Power key.
    - Keep pressing the keys until Samsung logo appears,Release all keys.
    - Wait until you get Factory reset / System Recovery menu on screen.
    - Use the Volume Down key to select Wipe Data / Factory Reset option.
    - Use the Power key to confirm the operation.
    - You need to use the Volume Down key again to select "Yes -- delete all user data"
    - Use the Power key to confirm.
    - After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
    - Now the phone will reboots, Wait for it to be fully on and then you can start using it.
    New Hard Reset / Factory Reset Method Using Odin3 Flasher:
    In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
    - Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
    - Download Odin3 flasher.
    - Put your phone into Download Mode.
    - Run Odin3.exe
    - Click on CSC button and Select the Hard Reset file.
    - Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
    - Click on Start button and wait until the operation done.
    - Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
    - Done.
    Jun 02, 2016 | Samsung Tab Tablets & eReaders
    How can I unlock screen without doing factory reset?
    Juan, You have to remember your pass code.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Check the attached links,instruction and guides, Good luck
    have forgot the screen unlock PIN code of my HTC how can unlock it now
    What to Do If You Forget Your Android Phones PIN Pattern or Password
    Reset Samsung Galaxy S2 S3 S4 Note2 Note3 Without Losing Data
    Reset Android password without losing data
    Mar 19, 2016 | Samsung Galaxy Core Prime G360M/DS -...
    Why my coby mid8065 stop working i try the reset button but still nothing happen, it show the coby logo and the android but didn't go far.
    Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
    Sep 08, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
    How do i reset factory settings on coby mid 8042
    Sep 07, 2014 | Coby kyros Tablets & eReaders
    I forgot my password to unlock the galaxy y screen what i have to do?
    1. Power off phone
    2. Press and hold Home Button ( middle ) + Volume Up + power on button
    3. Wait for 5 second until Android System Recovery menu appear
    4. There are 4 options
    reboot system now
    apply update from sdcar
    wipe cache partition
    5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode
    6. After the process done, phone will reboot.
    Jan 20, 2013 | Samsung Galaxy Y DUOS Android Smartphone
    My phone is locked, saying enter google account info but nothing works, also cant remember pattern either
    Best Solution;
    1. Power off phone
    reboot system now
    Sep 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
    Galaxy p1000 is frozen cant switch off nothing is happening
    Hope this helps:
    How to Hard Reset Samsung GT-P1000 Galaxy TAB:
    If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
    If this does not solve the problem, perform a factory data reset. In Menu
    mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
    Hard Reset Samsung GT-P1000 Galaxy TAB with keys With the Samsung Galaxy TAB turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
    Feb 05, 2011 | Samsung Galaxy Tab Tablet PC
    Cell Phones Logo
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
