Question about Sony Video Game Consoles & Games
Kdl-55ex620 red light blinks 3 times
I check the power supply so far
    Sergeant:
  • 236 Answers
Unplug your TV from the AC power. Press and hold the power button on the TV itself for about 10 seconds and then release. After another minute, plug the TV back in and press power once.
If the blinking is still occurring then this unfortunately indicates a failure within the TV and will require a service. If all OK then happy viewing!
Posted on Dec 09, 2014
Testimonial: "I try that same thing red light keep blinking 3 times over and over"
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Why does th3 Standby light blink 5 times on front of my Sony Braivo KDL-55ex620 TV.
HI
5 time red light blinking indicate that the T Con board is defective please replace T con but after replacing the t con board you must up date the SW because in some cases you replace the t con & 5 time is gone but there is no picture so in that case you must perform sw
thanks
Feb 14, 2015 | Sony Televison & Video
Hi I ve a sony KDL-40W2000 stuck on stdby red light flashing 4 times the stop for 3 second ??any advice please
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 16, 2014 | Televison & Video
Red light flashing 4 times
Malfunction of 5V line
(Voltage Supply to FE, etc) please check 5v power supply other wise change
BG1TW MOUNT (KDL-32V4000)
main system board
Jan 09, 2014 | Sony Bravia KDL-32V4000 32 in. LCD TV
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
My sony kdl 40 u 2530 e is not staring properly. the red led signal blinking 4 times periodically .any idea about the problem? If i turn off tv for hours then it starts for 2 minutes and again the same...
The tv power supply board have problems and the caused,check the tv power supply board have it fixed or services by u or tv tech.most likely those capacitors parts are dying on the tv power supply board like bulging or puffing up.Take the tv aparts,check the tv power supply board that board where the power a/c cord plug into it.Carefully check for capacitors parts for bulging and puffing up on to it tops.Changes all these dying capacitors,tv should be work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 18, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
T.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Aug 11, 2009 | Sony BRAVIA KDL-40V3000 Television
Video Game Consoles & Games Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
