Question about Microsoft Computers & Internet
To fix error code:Ox8007048f
While trying to pair mi3 with hcl me pc with windows7; error code :Ox8007048f is displayed and files from copmuter to mi3 could not be transferred.
    Top Expert:
  • Microsoft Master
  • 21,456 Answers
Make your computer discoverable and then when connected, turn discovery off to protect your data from others.
Posted on Dec 09, 2014
Kenmore error codes
Unfortunately this is a bad error code. Most times it is either the control panel or the main control unit. Both are expensive and there is no way to determine which has failed with out replacing them.
Sorry for the bad news.
Here is what the tech sheet has to say about the error code;
SERIAL COMMUNICATION ERROR
Possible Causes/Procedure
- Unplug washer or disconnect power.
- Check that the power cord terminals are connected at the right position to the RFI filter
(white-Neutral/ black-Line).
- Check the two ground switches are pressed correctly by the toe and rear panels.
- Check that ground switches are fitted correctly, and are not broken and the green
ground wires are connected correctly.
- Check both ground switches are not broken or have not scratch on them.
- Check that all the ground harnesses (green wires) are connected correctly and are not
broken or wires became detached.
- Check all wire harness connections from the CCU (MI3 cavity), main Motor and MCU are
not broken or wires detached and connector internal pins are visible.
- Check for continuity from the MCU connector wires to CCU (MI3 cavity) connector.
- If the continuity diagnosis failed the Main Harness must be replaced.
- Make sure that all the connectors are fully seated.
- Check the drive system for any worn or failed components.
- Plug in washer or reconnect power.
- Verify the unit operation by running a test cycle.
Sep 09, 2014 | Kenmore HE2 Plus Front Load Washer
I am getting error code 0x80070005, how do i fix this
Windows Activation Error : Error Code 0x80070005 I have upgraded my x64 Vista to x64 Windows7. After adding to companies domain, it asked to activate windows again. but its giving the following error when i try to activate it : "Windows Activation Error : Error Code 0x80070005"
The link for the fix is described at the Microsoft Website, link listed below.
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_install/windows-activation-error-error-code-0x80070005/90fb852d-a507-4c76-a672-0be2ecbdb320
Sep 30, 2013 | Toshiba Computers & Internet
I have a Kenmore model 11049962603 that displayed an f-71 error code. I ordered a new cpu computer from sears and installed it. the machine seemed to work for one or two loads. now it displays an f-70...
I provided a complete list of error codes for this type of washer in the image below. The error codes vary by the exact model of HE3t washer that you have. Since you have an HE3t that is displaying the F70 and F71 codes, the list below should apply to your model. These are not listed in the owner's manual because they are intended for technicians. Use extreme caution if you follow any of the troubleshooting described in this information sheet. Unplug the washer and shut off the water supply before accessing internal components.
The F70 and F71 codes indicate that you have a communication error between the CCU (Central Control Unit or main machine control board) and the user interface touch pad assembly. Here are some troubleshooting tips:
Make sure that you have the washer plugged into a properly grounded 3 prong 120 volt AC electrical outlet.
Unplug the washer for 30 seconds to allow the control boards to power down and reset. Plug the washer back in but do not touch the power button (or any other buttons) for 1 full minute. This may reset the control board. Pressing the power button too quickly after reapplying electrical power to the washer can cause the F70 or F71 code since the CCU does not have time to recognize the user interface control.
If the above tip does not help then the most suspect component failure is the MCU (motor control unit -- motor control board at the bottom of the washer beside the drive motor). You can check for this failure by unplugging the washer and then pulling the MI3 connection on the CCU. The wiring diagram below has the MI3 connection highlighted in red. The connection has blue wires. The third image below shows this connection on the control board. The connections are labeled on the control board. Press the tab at the bottom of this plug down and then pull it out. Power up the machine with this connection unplugged and don't touch any buttons for 1 minute. If you then press the power button to turn on the washer and don't get the F70 or F71 code then the MCU at the bottom of the washer will likely need to be replaced to fix this problem. A technician would normally be needed to verify this failure and replace the MCU. The MCU is expensive ($423).
This troubleshooting information is based on a common HE3t model that displays the F70 and F71 codes. If you need more help, submit additional details and the full model number of your HE3t washer.
Mar 27, 2011 | Kenmore Washing Machines
I am connected to internet but get error 651
I am assuming you have purchased a new pc with Windows7 and have a DSL internet connection. If so the following tutorial should prove useful. This is a common problem and known bug within the Windows7 framework that they are working to correct. Keep in mind that this fix is only applicable for the Windows7 operating system.
"The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can work around the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system click here to download raspppoe.sys file (unzip)."
http://www.windowsreference.com/windows-7/error-651-with-pppoe-connections-in-windows-7/
Once downloaded and unzipped you may rename the old rasppoe file as mentioned above by right clicking the icon and choosing 'rename'. Then copy the new rasppoe file you downloaded into the applicable folder. You will find this file in the following directory C:\WINDOWS\system32\drivers. Bear in mind, when searching for the file inside the drivers folder, the .sys file extension may or may not be included in the actual name. If the original file is named 'rasppoe' without the .sys file extension in the name, leave this file extension off when renaming and copying as well.
Dec 10, 2010 | E-Machines eMachines Desktop PC
Hello Sir, I purchased Acer Aspire 5745G two weeks ago. Yesterday My brother installed Fedora 12 and Windows7 was already instlled in it... Acer Customer Care Service suggested me to use Windows7 only. So...
The problem is with your Windows Boot file "bot.ini file" This file can become damage, corrupted or deleted for a number of reaons, (here seems the installation of Fedora 12) and id usually brought to your attention to by an error message befoe booting windows, the same message you are facing. there are two ways of removing it. 1-You can format your OS and re install it. or 2- repair your windows using the windows OS Cd.
Nov 15, 2010 | Acer Aspire One PC Notebook
How to fix error code. STOP: 0x0000C1F5
This issue occurs because the Common Log File System (Clfs.sys) driver does not fix the $TxfLog file when the file is corrupted. In addition to the Stop error message, Windows Vista may not start during startup until the offending disk is removed from the computer.
Support for Windows Vista without any service packs installed ended on April 13, 2010. To continue receiving security updates for Windows, make sure you're running Windows Vista with Service Pack 2 (SP2).
To fix this allow Microsoft Windows to update you to the latest service pack.
http://windows.microsoft.com/en-US/windows7/Install-Windows-updates
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 18, 2010 | Computers & Internet
Cmd problem
This is curruption in windows partition, most probably because of a virus. do following
  1. take backup of your important data
  2. use a good antivirus and scan PC
  3. if dosent work delete all partitions using thirdparty SW like diskmanager or Linux Bootable or another windows xp PC
  4. Reinstall windows and reportition.
  5. Try with another pair of RAM
  6. Pl dont forget to all device drivers/motherboard drivers before trying
if not succeed, please contact me
Zulfikar Ali
ali_zulfikar@yahoo.com
Mar 13, 2009 | Yahoo Messenger
My copmuter virus problem
Download AVG free as your antivirus
Download Adaware as your spyware cleaner
Download Malware Bytes as your other spyware cleaner
Feb 17, 2009 | Acer Aspire 3002LCi Notebook
Lost my laptop sound & display
I tried to search for the HCL drivers....it requires a specific code frm the laptop. Here's the link for tht page:
http://59.90.146.12:8080/examples/jsp/download/pon_index.jsp
In case of any issues, please let me knw
Jul 23, 2008 | VIA Balance Notebook Notebook
No sound
plz tell me after all your mp3 player run.......
hope some virus effect in your system....chack your anti virus 1st.
then setup your mp3 winamp 5.52 go to  download.com....thensetup properly...ok
Mar 02, 2008 | Computers & Internet
Computers & Internet Logo
143 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
