Question about Zanussi Washing Machines
How do I reset zanussi elextrolux 1200 hydrosystem 6kg
Errors with wash cycles, have cleared filter and emptied need to reset to normal?
dauphine
  • 207 Answers
SOURCE: just wont work
  1. Turn it off.
  2. Unplug it.
  3. Wait 5 or 10 minutes.
  4. Plug it in.
  5. Turn it on.
Posted on Apr 09, 2008
mnwarfield10
  • 452 Answers
SOURCE: what does E20 error on a zanussi progress 1200
pump blocked or broke
Posted on Jan 04, 2010
  • 174 Answers
SOURCE: Zanussi E30 problem
hi this can be caused by an earth leakage on the motor or more likely the heater it only needs a few mAmps to do this. you need an insulation tester to find which is the culprit. or try disconecting the heater to see if you can get the machine past the fill stage.
Posted on Jul 30, 2010
  • 298 Answers
SOURCE: i need a manual for
you can go to appliancerepairplanet.vstore.ca and go to contal us and we will see if we can get it
Posted on Dec 09, 2010
  • 430 Answers
SOURCE: what does e20 mean on
The error e20 indicates towards pump.The pump needs to be checked. The pump is blocked or broken.e20 is a not draining error code,check filter at bottom.could be faulty pump or something jammed in the impeller. --------------------------
You have a blockage in the drain hose I would suspect.
Keep putting it on drain till you get the water out or simply lower the drain hose into a wash basin.
Once it's empty, put a couple of towels down, unplug the machine and lay it carefully onto it's left side. Left side viewed from the front. (turn off the water first and disconnect the fill hose if necessary).
You can now take the drain hose off of the pump and take it out of the appliance to check for a blockage.If no blockage, you'll need to take the pump out and check that too.
Check the hose first.Also check for any small cloth getting blocked in the machine inside.
To remove the pump,It's clipped into the base.Look at the underside of the base.Squeeze the clips together and push them into the base a little.You can then slide the pump out of the filter housing.Watch for the O ring as this has to go back on to seal the pump.The pump slides in and out.
You'll only need to unplug the wiring.If hose or pump checked out faulty then it has to be replaced,if filter is clogged clean it.
---------------Thanks.
Posted on Mar 01, 2011
Problem with hotpoint aquarius wml520p 6kg 1200 spin washing machine doesent go into final spin
Have you checked the filter if fitted? Sometimes washing machines will not spin if they're not empty.
Jan 19, 2015 | Hotpoint Washing Machines
Zanussi 1200 6kg, not spinning or taking in water ?
Try unplugging the unit for 30 mins. then run it again.
Nov 21, 2012 | Washing Machines
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
My machine does part cycle than all lights flash than when restart it will start washing but want go throw the cycles ie rinse spin drain
Teh make and model of the machine is important here, because WHICH lights flash and the number of times they flash is an error code taht we can look up if you tell us the make and model. However, from what you have said so far, this likely to be a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 06, 2011 | Washing Machines
What does e20 mean on a zanussi electrolux progress 1200 hydrosystem
Mar 01, 2011 | Washing Machines
Zanussi E30 problem
Jul 30, 2010 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Wont drain, wont empty, wont go onto rinse, drain or spin during
The filter on this machine is behind the flat at bottom right of machine. Tilt machine back before unscrewing to avoid spillage. If filter is clear get back to me and will explore other possibilities.
Nov 16, 2008 | Washing Machines
Just wont work
  1. Turn it off.
  2. Unplug it.
  4. Plug it in.
  5. Turn it on.
Apr 09, 2008 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
