Question about Bosch KGV36NW20G 60cm Classixx Freestanding Fridge Freezer
I have got a Bosch KGV36NW20G Fridge Freezer and it's only 2.5 years old. Some problem has occurred recently. I can hear that water or some fluid is flowing around in the Fridge Freezer all the time, which never happened before. It is has been constantly working for a few days without stopping. The temperature is about 12 Celsius in the fridge and -3 Celsius in the freezer. Has someone experienced such problem before? Is this a hardware problem? Any ideas / advices would be very much appreciated.
    Novelist:
  • 187 Answers
From your description, it sounds like your condensing coil is dirty and needs cleaning. You will probably find the coil and fan inside the back cardboard cover area. Once a condensing coil gets so dirty, the refrigerant condensed in the condenser is so hot that it does little cooling effect because of the internal heat consumes any refrigeration effect left in the refrigerant. This is vary common problem and especially for pet owner. The pet fur and hair get caught in condensing coil and block air flow.
Hope this helps
Posted on Dec 14, 2014
I have a free standing bosch fridge/freezer. There is water that is under the fridge and the alarm came on for the freezer section. I turned on Supercooling overnight and switched back to the original
It could be a defrosting issue. Make sure when you unplug your unit and let it defrost for 24-48 hours, make sure you put rags around the unit so if drain pan over flows, rags will absorb any excess water. If unit is partially defrosted, you will see water inside the freezer underneath.
Jan 02, 2018 | Bosch Refrigerators
Formation of ice in freezer compartment
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Sep 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Bosch KGU44120 frost free fridge freezer (6 years old) generates ice on floor of freezer compartment within a couple of hours. Maintains -20C temperature no problem.
drain is blocked in freezer. take back panel off inside the freezer and you will probably find that the bottom is covered with ice. melt off with a hairdryer and hot water till water flows freely down the drain. needs a bit of patience
Jul 04, 2008 | Bosch Refrigerators
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Bosch KGV36NW20G 60cm Classixx Freestanding Fridge Freezer Logo
180 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
