Question about Sebo X4 Extra Bagged Upright Vacuum
How do I replace the front bottom plate on my Sebo X4 Extra vacuum cleaner, this is the metal/plastic plate on the front base of the bottom of the cleaner (no visible fixings)
    New Friend:
    Problem Solver:
  • 12 Answers
With the power head cover removed, you will see tabs on the inside of the chassis inline with the front bottom plate. Simply pinch the tabs with some needle nose pliers and push. I have included a link to the parts list as well as the front bottom plate. You will see by the picture what those tabs look like and how to remove the front bottom plate. 5411 HG Front Bottom Plate Windsor Sensor S12 XP12 SR12 86138280 allstar... http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Posted on Dec 10, 2014
Orange spring will no longer hold cleaner in upright position.
You may need a replacement spring just a guess so here's the list of replacement parts with prices best of luck! Spare Parts AUTOMATIC X4 SEBO Vacuums Online Store
Jan 07, 2016 | Sebo Automatic X4 Extra Upright Vacuum...
My Sebo vacuum cleaner makes a whistling noise when standing upright
similar to the air relief on my dyson think it is so they don't burn motor up
Feb 17, 2015 | Sebo Automatic X4 Extra Upright Vacuum...
How to fix squeaking and bag full sign lit on the sebo x4 extra upright vacuum?
Check the main "kitchen roll" filter isn't clogged which is on the left hand side of the bag when the bin door is opened. There could be a clog, either behind the pick out metal grid below the filter roll, or the roll filter requires to be replaced. Can you add more info about the squeaking though? Is it a high pitched squeal all of the time or just intermittent and where it seems to be coming from - it could be excess air escaping from a pierced hose or a drive belt issue.
Oct 30, 2013 | Sebo X4 Bagged Upright Vacuum
I need a new set of instructions for my sebo x4 extra upright cleaner
you will have to call sebo or the dealer you brought it from to get manual
Aug 27, 2010 | Sebo X4 Extra Bagged Upright Vacuum
My sebo x4 extra does not start. There is power but no warning lights are flashing. When I turn the vacuum on there is a continual clicking/buzzing sound.
Hi.
Eeither motor or servo motor with gear box is seized. Testing is done energizing the motor. Test and repair must be done by a technician. Call the number listed on the owners manual to contact a qualified repairer.
See: Parts List and schematics SEBO X4
Jul 31, 2010 | Sebo X4 Bagged Upright Vacuum
Bag full or clog light comes on but new bag and no blockage... Sebo x4 upright cleaner
Have you checked the filters to see if they are blocked and need cleaning/replacing. Failing that it could be the sensor at fault.
Jul 25, 2010 | Sebo X4 Bagged Upright Vacuum
I want to release flex from sebo x4 vacuum cleaner to cut back...
On the underside of the handle, there's a small screw close to where the metal and plastic parts join. Undo this screw. This will allow you to pull the plastic part out of the metal part - not very far, but just far enough so that you can separate the plastic part into two halves lengthways. That gives you access to the switch, and you should find the rewiring job and reassembly straight forward from there on.
I hope this helps. If you need more, just post a reply and I'll get back to you as soon as I can. I do value feedback, so please remember to rate this answer.
Mar 06, 2010 | Sebo X4 Bagged Upright Vacuum
I have mislaid the instructions. How do I separate the top from the bottom to check for a clog.  Sebo Automatic x 4 extra 1300 w
To separate the base from the bag compartment: press the button at bottom front centre of bag compartment and lift bag compartment upwards away from base. Sometimes this is quite stiff and four hands would be useful, you can lever it from behind with something relatively soft (the plastic handle of a dishwash brush works well) but take care to lift vertically upwards, not sideways or you risk bending a metal lever that's hard to get back into shape again. Rest assured that once you've pressed that button there is nothing holding the two parts together other than friction!
The vacuum tubes are very obvious, and sometimes there can be a blockage in the one to the rear (without the little criss-cross sieve in it.  You should also look up the tubes that go in to the bag compartment.  Remember also that there's an inspection flap on the underside of the base.
I hope this helps.  If not, please post again and I'll try again.  I value your feedback, so please remember to rate this response.  Thank you.
Apr 26, 2009 | Sebo X4 Bagged Upright Vacuum
Replace power cable on Sebo X4 vacuum claenaer
From memory the plastic part slides up a little, enough for you to access the wiring. I'll try and have look at work tomorrow.
Warning though! you need to do this work with the handle laying flat, the screw hole upwards - it may be already too late as there is a nut that slides away and can be tricky to get back
Feb 03, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
I need to know how to repalce the drive belt in a Sebo upright cl
Thanks to its automatic height-adjust feature, the Sebo X4 has two drive belts, one from the motor to the height-adjust sensor, and another from that sensor to the brush roller. To access them,first remove the base from the handle, undo the four recessed screws on the underside of the base, then turn it over and lift off the cover. You will then see the belts. The rest should be obvious (it's a while since I've done one of these, but I think you may have to loosen the screws holding the height-adjust sensor before you can slip the belt off).
I hope this helps. Any further problem, just re-post here and I'll do my best. Good luck!
Feb 01, 2009 | Sebo Air belt K3 Bagged Canister Vacuum
Sebo X4 Extra Bagged Upright Vacuum Logo
179 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
