Question about Pride Mobility Victory 3 Wheel Electric Scooter
Pride Mobility Scooter just put in new batteries went to the shops and on the way back just stopped had to push it home not good shop is only 1Km away now it seems ok but don't want to risk it. Red li
Fitted new batteries.
  • Mike
    Mike Dec 09, 2014
    did that beforw starting out. Turned back on a few hrs later (Without charging) indicator was full and runs? only this flashing light above battery indicator. Checked batteries with meter both reading 13.2 V ?
  • 720 Answers
Needs a full overnight charge of at least 12 hours and left on charge even when the lights tell you it's is charged up.then get into the habit of running it right down to improve the storage stamina of battery.good idea to take charger out with you so if you get a chance to top it up somewhere whilst away from home.remember in cold weather these things can't travel as far.
Posted on Dec 09, 2014
My Pride Revo Mobility scooter needs a new gear box.
never said how old it is,cant give you a good answer without knowing.
Sep 13, 2012 | Pride Mobility Revo 3 Wheel Scooter
1997 PRIDE VICTORY GIVEN TO ME, BUT NEEDED FRESH BATTERIES PURCHASED NEW BATTERIES INSTALLED THE KEY, LITES & HORN WORK BUT UNIT WILL NOT MOVE FORWARD AND/OR BACK
check the freewheel lever on th rear of the chair near the right rear wheel if you can push the scooter easily then you are in freewheel locate the lever and move it to the drive mode and try to drive the scooter again if it still won't move then you have other problems that can only be checked by a service tech Hope this helps
Feb 26, 2011 | Pride Mobility Products Pride Mobility...
The scooter was working fine my father added weight to the foot plate shopping now it wont drive its a shop rider
Check your breaker ,its right there on the footboard ,If the chair may have been overloaded it may have pop your breaker.
good luck sir ,
Jan 23, 2011 | Pride Mobility Products Pride Mobility...
I HAVE A PRIDE 3 WHEEL GOGO SCOOTER. THE BATTERIES WENT DEAD. I REPLACED THEM AND CHARGED THEM UP. NOW I GET A 5 BEEP CODE WHEN I TRY TO START. IS THERE A LIST OF WHAT EACH CODE IS? THANKS FOR YOUR...
Hi Fred,
Good job on replacing the batteries!
With the go go scooter, a beep code of 5 indicates a solenoid brake trip. This means that the brake manual/freewheel lever may be in the freewheel position. This means that you can push the scooter. Remove the key and push the freewheel lever to the drive position. Restart the scooter and the code should be cleared and the scooter will run. Hope this helps.
Jan 19, 2011 | Pride Mobility Products Go Go Ultra X 3...
Old BEC Stirling 4. just stopped!
There will definitely be a fuse or thermal cut-out (or two) for the batteries, but those must be OK. Double check wiring to the motor? Was motor or controller very hot?
Aug 30, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Charging light wont come on, this is my first time charging scooter
make sure the outlet your using to plug in the charger is good (plug in a lamp,light or radio to check) if good make sure the charging cord is plugged in all the way. If you using an extention cord, try without.
Jul 12, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I own a pride mobility scooter with an issue of stopping
It could be a loose battery connector and the controller heats up when it's trying to pull amperage out of the batteries but can't because of the loose connection Try tightening bolts on batteries but disconnect them first. Also it could be the brake on the motor and if the unit isn't shutting off the lights on the tiller blink in patterns to let you know what problems to check for.
Feb 26, 2009 | Hurricane Pride Pmv Mobility Scooter Candy...
Battery power on mobility scooter
Most scooters show a drop on the battery level meter when in use, as long as it is`nt slowing down it should`nt be a prob. I mean,when you engage the throttle you ARE putting a load on the batteries,so it`s only par for the course that the indicator would drop a bit.
Jan 04, 2009 | Pride Mobility Products Pride Mobility...
Pride Mobility Victory 3 Wheel Electric Scooter Logo
104 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
