Constantly jammed paper when print or copy multiple pages
Only when print (copy) double-sided copies or more copies, paper jams in the MF. Paper is pushed into the fuser (paper is slightly curled) - fuser already stopped, other papers in the printer are slightly twisted. I need to know how is the paper path, maybe somehow the path is wrong. Thank You!
    Habit-Forming:
  • 91 Answers
Check if the paper size not match with that sitting in printer sitting and the aplication you use
Posted on Dec 09, 2014
    Top Expert:
  • Office Equip... Master
  • 74,377 Answers
Mechanical fault. Contact the authorized service center. Please do not try to adjust anything by yourself.
Testimonial: "I repair that kind of machines for over 30 years. I think I ask a brother. Anyway, thank you for answer!"
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
jaylex
  • 417 Answers
SOURCE: False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
Posted on Dec 31, 2007
  • 5 Answers
SOURCE: Paper jams
This is a clasic case of the rubber feed rollers simply being worn and dirty. You can check the clutch to make sure it is turning the feed rollers by barely starting a feed and stopping the machine. The rollers will be in a different position. A second way is to take the paper tray out and trip the paper tray switch all the way in back, then start a feed and put (just a LITTLE pressure) with your finger on the roller to see if is aggresively turns. This will prove that the clutch is good.
DO NOT USE alcohol since this will clean the rubber rollers but make them fail much sooner. Use eucalyputs oil (4 oz bottle in health food stores for $5 will last for years) with a cloth and clean the rubber pickup rollers. If the leading edge of the rollers looks a little shinny you need to barely roughen the entire surface of the roller up with (60 to 80 grit) sandpaper (especially the leading edge) and then clean it again with the euclyptus oil. This will take about 20 minutes to dry and your rollers will pickup paper as good if not better than when they were new.
Posted on Jan 23, 2008
  • 33 Answers
SOURCE: Panasonic DP 2500 J81-J82 paper jam
Check the sensor lever spring and cable on top of dual path guide (on top of fuser unit) also if the door stopper has been broken there is a good chance the door may be slightly deformed in which case a gentle adjustment may be reqd. check on the diverter solenoid there should be NO spring attached to the white guide. that is supposed to be removed when the adu option is fitted.
Posted on Mar 05, 2008
kevin000
  • 1847 Answers
SOURCE: Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Posted on Sep 09, 2008
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Paper Jam at bottom of duplex path
are you running multiple pages when this happens? try just one double sided copy and see if it does it then also. it could be caused by a paper path issue some where else in the machine.
Sep 06, 2014 | Samsung SCX Office Equipment & Supplies
I have an imagerunner 2800 and it only seems to jam in the tray loading area, just bends the long side of the paper randomly. It changes it's performance just like the weather, sometimes I can get multiple...
A couple of things to consider:
Do not load the following types of paper in the paper drawer. Doing so may cause a paper jam.
- Severely curled or wrinkled paper
- Heavyweight paper
- Transparencies
- Paper on which color images have been copied.
- Paper which has been copied on using a digital full color copier (do not copy on the reverse side
either).
- Paper which has been printed on using a thermal transfer printer (do not copy on the reverse side
either).
Also, what # paper are you using?
Oct 12, 2013 | Canon (6981A002AA) for imagerunner 2200,...
How to avoid paper jams?
hi,the best way to avoid paper jam is cleaning.clean
first paper transportation area,second paper feed rolls in trays.send me result
May 31, 2009 | Canon PC-921 Black and White Copier
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Printer says paper jam and stops- but it is not jammed
your description indicates you need to thoroughly check printer for any bit of paper ........rolller too has to be checked so that paper is moving smoothly ......
Feb 02, 2009 | Brother MFC 420CN All-In-One InkJet...
74 people viewed this question
jasbo
jasbo
