Question about APC Computers & Internet
How do I get a schematic of a UPS SUA1500I been trying for 3 hours now seems like nobody has one
New won't startup, I'm assumeing there is a bad switch board connection or power diode bad
    Top Expert:
  • APC Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 09, 2014
Apc smart ups vt - no mains detection
be more precise
more info needed. what did you do. how did U startup the unit?
Mar 14, 2015 | APC Smart-UPS VT (SUVTP30KH3B4S) UPS...
Car is very sluggish when going up hill I replaced plug and wire also fuel pump checked for vacuum leak
a Isuzu, engine, but which one, the honda ugly duckling made out of
desperation, bad bad bad... that idea....
2.6L 4ZE1 SOHC eight valve engine features 120 hp (89 kW) and was available as an option to replace the 4ZD1 on four-wheel-drive models
or the V6>?
3.2L 175 hp (130 kW) V6
nobody can fix any car engine ,not know what they have.
the 2.6L
my online FSM shows nothing for passports, (bad news)
so i look up rodeo ,
that to has poor docs.
but the 2.6l is MAF bases
the 3.2l is map (the drawings are faulty but seems to be mAP
so as per usual. no engine, no joy.
on the 2.6L
Bogging (full time bogging not transitory is)
is:
1: dirty MAF. or air leaks behind, it.
2: air leaks to the plenum. from any source, causes lean bogs
3: clogged injectors
4: low fuel pressure,
5: bad fuel.
ill assume it tuned up, nobody diagnoses cars not tuned, unless rich.
i assumed it not missfire, misfire is violent and not a bog that is smooth and lean loss of power.
there are simple tests for each .
we can test, or gue$$.
if v6, add clogged map nipple, the vacuum port packed
with the ubiquitous PCV/EGR cloud of death.
Feb 04, 2014 | 1995 Honda Passport
Where can I get schematic for this unit?
Apperently APC has a policy against releasing schematics
Read
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | APC Smart-UPS DP 6000 UPS System
After switching on the power supply, my pc takes around 3-4 minutes to start with APC UPS, earlier it was responding within half a minute
Have you taken it off the UPS and tried connected direct to an outlet.
Does it take the same amount of time?
If so you have a software or hardware conflict that is new and needs to be researched carefully.
try using the windows error log to see if there any startup errors.
Nov 26, 2009 | APC Back-UPS CS 500VA UPS System
Any schematics available for a APC Back-UPS Pro 650PNP? I installed a new battery (yes correct polarity) and smelled a little smoke. It was unplugged during the battery swap. I took the cover off but...
hi, i don't have the schematic but, i think if you connected the batteries okay and had switched off the machine then it should work. when switching on there are two sounds that come, first its a beep, if you release the ON SWITCH the UPS will just do a self test then shutdown. to switch ON the UPS completely don't release the on button until you hear a second beep, if you release the ON switch when this beep is on, then the UPS will be ON completely.
Nov 09, 2009 | APC Back-UPS Pro 650 UPS System
Need a schematic for a belkin F6C120-unv. All functions of the unit work fine other than the charging circuit won't keep the batteries charged. Runs about 24.7 volts, but keeps getting lower as the...
When batteries discharge during ac power it could indicate charger failure or micro failure or some other wierdness. makers do not release cd info. The best thing is.. buy another one as they can be very difficult to repair and of course they are dangerous, batteries are always live, waiting to bite you. I have worked on and repaired such circuits as the AP 200 series resonant converter and selling and hiring UPS for a long time. Beyond the simple easy checks youhave done the time it takes to understand how they work can better be used.
Sep 22, 2009 | Belkin Enterprise (F6C1200-UNV)...
APC external Backup battery is not working plz
It may just need a new battery. The UPS will do a self test on the battery when you turn it on. It may have tried to read the battery and the result came back as "failed". The batteries last about 3-5 years, even less if you live in an area with bad power. The batteries are very easy to change. You can buy replacements at www.batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
Jun 08, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
UPS Thermal 2844 errors out every few hours without use.
You probably need a better driver. Try www.seagullscientific.com or call Andrew @908-725-1699
Apr 26, 2009 | Zebra LP 2844 Thermal Printer
Dynex Te685avr backup battery doesnt work
If the battery outlets do not work, typically the Dynex TE685AVR UPS (battery backup) just needs a new battery. These batteries usually last 3-5 years.
The model of the battery is a WKA12-7.5F2 and can be purchased at: http://www.replacementupsbattery.com/Product_pages/wka12-75f2.html.
Jun 26, 2008 | Dynex (TE685AVR) UPS System
Computers & Internet Logo
140 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
