Question about Clothing Accessories
How to fix a broken ring? - Clothing Accessories
    Problem Solver:
  • 8 Answers
  • First determine if it is costumer jewelry or fine jewelry. You can tell this by looking inside the band. Gold will have: 10k, 14k, 18k. Silver: 925 and Platinum: 900 950 or 999. You should take this ring to the Jeweler to fix if it meets any of the above criteria.
  • If it doesn't have any of these marks, it is probably costume jewlery. Some costume jewelry is expensive. If you didn't pay alot for it, there is glue you can buy expressly for this purpose from the craft store. You might want to practice before using it. Youtube has some great videos on jewelry repair. Good luck!
Posted on Feb 26, 2015
    Welcome Back:
    Visited the website for 2 consecutive days.
Take it to the jewellers shop that you bought it from they will fix it for you
Posted on Feb 25, 2015
  • 682 Answers
Take it to the jewellers who can repair it properly as they use heat and the correct material to make a good join.
Posted on Dec 09, 2014
Spark plug has oil inside of it y would this happen
SOUNDS TO ME YOU M AY HAVE INTERNAL ENGINE DAMAGE IE BROKEN RING
Nov 01, 2014 | 2002 Nissan Maxima Spark Plug
How do I replace ring that toilet attaches to the floor
If the ring that is attached to the floor and sewer pipe is broken you can get a new ring that fits over the old one ..depending on the type of floor if wood you just screw new plastic ring over the old one be sure to line the bolt slots at the 3 oclock and 9 oclock position so you can slide the bolt head under the new ring and lines up to keep the bowl holes in exact spot. when you put the new wax ring on be sure to get one that has a built in plastic flange that goes down inside the 4 inch sewer pipe before putting plastic wax seal on be sure new ring is snug i always use a course wood screw to screw to the floor if you have concrete you will have to place ring make mark for screw holes drill masonary bit then put insert into concrete then put ring on then coarse screw good luck this should solve the issue
Sep 04, 2014 | Home
Phone does not ring
Time to get new phones. You incoming wires are not operating on the base of the phone. It is called the 'ring-side' or 'red' wire. Unless you know where the break is, you cannot fix it. because it happens on all the phones....it has to be broken in the base that serves them all. This isolation is furthered by the fact that a corded phone works fine on incoming calls, so it is not in the line to the building, broken on the ring side that is. Happy phone hunting!
blkqueentech
Apr 05, 2014 | Panasonic KX TG6511 Cordless Phone
Broken battery cover
Hi, I usually fix broken battery cover by sticking it with quick adhesive tapes. If battery cover is still not staying with the case then try using soldering iron any heating element to make a an extrusions so that it fix with case.
Oct 18, 2012 | Vivitar 5000 Ring Light Flash
Excess smoke
The general rule: white-ish smoke indicates coolant in the exhaust, meaning a blown head gasket, whereas darker smoke indicates motor oil in the exhaust, which means that one (or more) cylinders have a broken ring, and the engine needs a ring job.
Fix for white smoke: replace head gasket.
Fix for black smoke: ring job.
Oct 05, 2011 | 2003 Lexus ES 300
I have a 2001 jeep grand cherokee.I dropped the trans pan and found a broken ring.The suv is changing out at high rpm's and i am wondering could this be the problem because it was'nt doing it...
hello angela.... the transmission is the most complex part of the automobile. go to any AAMCO shop and they will take a look at it and give you a free estimate. you are correct to assume that the broken ring is behind your problem...replacing that ring requires special tools and knowhow, it is definitely not a home repair. Joe
Jun 13, 2011 | 2001 Jeep Grand Cherokee
Vaccuum cleaner with a broken hose
Is it just the corrugations of the hose broken? With most hose fittings there are two small oval shaped lugs on the side of the fitting. Grab a small screwdriver and gently (you may need a little force) push these in to ease the click ring out.
Once out, you'll find a type of screw cuff. Some hoses just unscrew, some are glued in (use boiling hot water to soften to separate).
Cut the broken piece of hose off, make sure the click ring is still on the hose in the right direction, reaffix the screw cuff, and replace the hose (with click ring) back into the hose fitting.
If it's actually the hose fitting broken, check with your local Wertheim retailer or repairer.
May 20, 2010 | Vacuums
The drum got loose because the one of the top drum springs got unhooked. The spring holder on the plastic drum cover is broken. It was noticed in time and turned off. So it seems that nothing else is...
will the plastic ring in the second ring move to the other ring . the danger is if you put the spring in the second ring the drum may not be line up straight when you look from the top (the motor may be further back) causing the motor and back to rub on the back plate when loaded might be better to drill new hole ?
Feb 11, 2010 | AEG Lavamat 88840 Front Load Washer
How to fix a broken 20GB 360 hard drive?
the only way to fix it is to ring microsoft explain it to them then they will give you a code to format the hard drive and start over hope this helped u
May 05, 2009 | Microsoft 20GB Hard Drive for Xbox 360
Clothing Accessories Logo
221 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
