Question about Lands Phones
I have a BT6500 phone showing line cord error - have checked both are plugged in and connected and all lights on but still showing error
  • Lands Phones Master
  • 3,368 Answers
I do not have this one but try reversing the plug. I assume other phones work.
Posted on Dec 09, 2014
I've just bought the above phone and connected tomains to charge batteries and handsets show "line chord error" is this because the phone line has yet to be plugged in?
yes, it will either show line cord error, or no line. After phone is charged plug line cord in and it should go away if not check line cord or try another known good cord.
Aug 11, 2015 | Lands Phones
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
Check line cord phone mean
The cord or cable connecting the phone to your pstn line is called line cord. check the connection at the back of phone and the wall jack. if it is ok change the cord and check.
Jul 20, 2013 | British Telecom Synergy 2110 Cordless...
I have a problem in my ATM machine.. it shows the error on screen ( communication down) i check my telefone lines its ok ..... and there is no problem in brain net connection ..... plz some one help me...
Different ATM Machines have different error codes. If your ATM machine is experiencing a communication failure it could be a bad modem board, or just a simple phone line problem.
I suggest starting with replacing the phone line. First, plug a regular phone into the wall phone jack, make sure you have dial tone. If you do, get a brand new phone cord and run that into the top of your ATM. Disconnect your ATM phone line inside the head of the ATM and plug that new cord in there. Try and clear the communicaiton error. If that works, try a transaction. If that works, replace old line with this new one.
If that doesn\'t work, make sure you didn\'t lose master keys, and that your ATM is actually online with your processor.
If you are not getting good service, and your ATM has been down for days, you should look into changing your ATM processing.
Google ATM Processing or call 888-501-5246
Dec 05, 2010 | Computers & Internet
When faxing it's saying phone line error what does this mean?
Hi, whenever you have a Phone Line Error, it means that
A: The Line isn't connected.
B: There is a fault on the line prohibiting successful transmission and reception of FAX.
C: There is a fault with the Modem in the FAX.
So Check there is actually a working line & connected up.
Check that the line is OK, get your Telco to test it.
Check the Modem in your FAX. and that the cord is plugged in correctly Check your phone cable.
Aug 19, 2010 | Dell 946 All-In-One InkJet Printer
I've been trying to send fax for a couple days now. The fax is connecting, then it never connects and a sheet prints show Error 388. I've tried plugging fax into new jack and all, but it still doesn't...
This error shows that there is too much noise / interference on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Check that the phone cord is plugged in correctly on the printer and in to the telephone Jack. Also check that the phone cord is not damaged in any way. If you have other devices sharing the phone line on the premises or sharing the phone socket than disconnect them to see if this allows the fax to be sent successfully. This could also be a general problem with the phone / fax line outside of your premises and could even be at the receiving end. Try faxing a message to someone else. Then retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Oct 09, 2009 | HP Officejet 6500 Wireless All-in-One...
Second line not working
The phone will show that "line in use" message when it's not connected correctly.
If your two phone lines come in to one jack, make sure you are using a 4-wire line cord connected to the "line 1 and line 2" jack on the phone. You may be using a 2-wire cord so the second line isn't reaching the phone.
If the two lines are on separate jacks you need to connect line 2 to the separate "line 2" jack.
If you know for a fact that both lines are properly connected to the phone and it still doesn't see the second line, then it's time for a new phone.
Dec 10, 2008 | AT&T E2562 Cordless Phone
Fax machine shows message "external phone". Machine is a Philips Magic 3 primo
The message means that a telephone connected to the machine is off hook. Either that or the internal relay that seizes the line after a phone is used has hung up. In that case, try removing the power to the machine and unplugging the line and any other phone cords connected to the machine. Then 1st plugging in the power cord and wait until the machine powers up. If the error code doesn't appear, then plug in the line cord.
Aug 19, 2008 | Office Equipment & Supplies
Lands Phones Logo
323 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
