Question about Kenmore Microwave Ovens
My Kenmore elite built in microwave oven model 790 488 03100 has stoppped heating what can i do
The oven is 16 months old and was working fine now it has stoped heating sears is no help at all everything looks and sounds like its working no heat the only thing that warms up on the inside is where the light bulb is i tried heating a cup of water 4 min on high no change in temp what can i do
  • 88 Answers
It may be a bad fuse or capicitor. I have had a time in the past with something similar. I contacted Repair Clinic.com. They were very helpful with their advice and even followed up to make sure I got things fixed okay.
Posted on Dec 10, 2014
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Galaxy Microwave Hood Combo Model 72180002400
Since it sounds louder than before, it is probably a bad high voltage diode or magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
Sears may send you a magnetron to install yourself since it's under warranty. For that or warranty service, contact Sears at http://www.sears.com.
You can save about $75 by taking it to the shop yourself, as opposed to an in-home service call.
Posted on Aug 08, 2008
SOURCE: Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Posted on Nov 09, 2008
SOURCE: Short circuited Whirlpool MH1150XM while changing the bulb underneath. Need help to fix it, thanks :)
We replaced the board behind the control panel. $130.00. If you do this make sure you can put the wires back the right way. My husband finally got it and our micro is working like brand newThanks to all who tried to help.
Posted on Jan 14, 2009
built in 3/94 is it worth fixing how much for magetron
Posted on Feb 12, 2009
SOURCE: My microwave oven isn't heating my food.
Small component called a diode. Open up the microwave and try to find a black (usually) component that is most often connected between the magnetron (the thing that heats the food) and the chassis of the microwave oven (ground). I used to make a fortune replacing these! Costs about 5 bucks most appliance supply stores. Make darn sure you get one of the same value.
Posted on Apr 06, 2010
Kenmore elite model 721.80822500 convection oven won't heat. Microwave and other functions fine
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
May 06, 2016 | Kenmore Microwave Ovens
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Sep 10, 2013 | Kenmore Elite Microwave, Model...
Hi, i own a kenmore elite speedcook oven model 363.63692301, ever since my wife used the convection speedcook oven and had the heat setting set to the maximum temp of 450 degrees which the oven should...
I have had issues with my Kenmore Elite conv oven too. I have had several service calls and found out that the TCU (thermal cooling unit) sensor was not working. This allows the oven to cool down so it doesnt overheat the sensors in the display. I actually had to have the oven replaced after 4 months of use. I am currently waiting for a technician to review the replacement oven for the same issue. I spent $7k on all new Elite appliances and will never purchase Kenmore appliances again. Good luck
Nov 30, 2010 | Kenmore Microwave Ovens
My kenmore ELITE 721.64282 microwave/convection just stopped
I just had the exact same problem. :( Did you find anything out?
May 23, 2009 | Kenmore 63792 Microwave Oven
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Microwave heats but slowly.
This is the second time I have requested assitance on this site with no response. The beginning of this thread dates back two months. Why would I ever want to pay for support when it is so poor at this level?
Jan 06, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Ovens Logo
114 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
