Question about Epson Stylus Pro 7880 InkJet Printer
How long can a usb cable be to a printer
Connecting an iMac to a Epson 7880 about 8-9 meters (9-10 yards) away.
    Problem Solver:
  • 3 Answers
9to 10 yrds
Posted on Dec 09, 2014
IB4G2008
  • 3587 Answers
SOURCE: epson c62 printer parallel to usb
well...those are particularly quirky. Does the epson site suggest this is possible to use? I've not seen that happen too many times, due to the mix up from parallel interface to usb...usually it takes an active converter to accomplish this.
I'm assuming your computer has no usb ports?
what operating system are you running?
Posted on Mar 25, 2008
yooperbud
  • 8637 Answers
SOURCE: communication error between Epson Printer and iMac
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Fixe_You
  • 1800 Answers
SOURCE: Connectivity of printer with newer computers
does ur unit have The LPT connection or COM ports .
u can use this ports as a alternative connection.
also check for MAC converter cables!!
plz rate this post as good as u can
Posted on Feb 06, 2009
  • 71 Answers
SOURCE: connect printer to PC
the problem here is that the printer use an old cable, and need a parallel port, it was used before usb became a standard for any device, and the problem is that computers manufacturers avoid to provide new pc with old technology like floppy or parallel ports.
To solve this you can: - buy an adapter that convert your parallel port cable "DB25" to use with USB port - buy a parallel port card (usually a card to plug in your PCI slot)
cheers
Posted on Jul 27, 2009
SOURCE: Hi I installed a new cartridge
I installed a new cartridge vivid magenta on my Epson Stylus PRO 7800 and got same problem. Need help
Posted on May 07, 2010
The error code 0040 appears on my epson 7880. How can I solve it? Help me please!
You probably need a maintenance kit. It consists of new ink waste padsicon1.png, a purge unit, and some other little parts. Contact Epson support
Jul 30, 2015 | Epson Stylus Pro 7880 InkJet Printer
Epson stylus pro 7880
maybe there is a problem in the chips of the cartridges (made in china :) ) or search for reset instructions ( if there is) somewhere in internet .
Good luck
Jul 24, 2012 | Epson Stylus Pro 7880 InkJet Printer
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
Epson R1800 On Print Preview of a photograph
I print with the R1800 as well as the 24" 7880 in my studio. Whenever the "preview" shows less than the whole image I intend to print it is generally either the orientation (portrait/landscpe) is set incorrectly or the Paper size selected is incorrect for the size of the print.
Hope this helps
nickerjo
leaningpalmstudio.com
Mar 01, 2010 | Epson Stylus Photo R1800 InkJet Printer
What does error code 1000060 for the epson 7880 mean?
1. Measure the resistance value of the CR Motor. (5.8Ω)
If the CR Motor is found in short mode, replace the C472MAIN Board at the same time.
2. By visual inspection, check the T Fence for any defect, such as damage or soiling, which can cause faulty reading by the sensor.
3. By visual inspection, check the harness of the CR Motor for any problem causing a short circuit to the frame.
Dec 22, 2009 | Epson Stylus Pro 7880 InkJet Printer
HP PHOTOSMART C4280 ALL IN ONE WHEN USING IMAC 10.5.7, PRINTER SHOWS MESSAGE USB NOT CONNECTED
You need to try isolating the problem first.
1. Try connecting the USB cable into different USB port of your Mac Leopard.
2. Make sure that your computer could detect other USB devices.
3. Try connecting the printer into different computer to see if the printer would be detected or not.
4. Use different USB cable.
If you get the same problem, you need to contact the printer manufacturer. I believe that it is more on physical connection.
Have a great day!
Jun 22, 2009 | HP Office Equipment & Supplies
Feb 06, 2009 | Epson Stylus Color 3000 InkJet Printer
"Communication error"
HI-
How do you connect the printer to your imac? what type of cable are you using? if its a USB connection, then try going to system profiler and under hardware click on USB and on USB device tree you should have highspeed USB 2.0 and when you highlight that, it should give info for manufacturer as EPSON if thats the brand of the printer you are currently using. update me on this so that we can check if its really communicating with your imac-- thanks!
Jul 07, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus Pro 7880 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
