Question about Coffee Makers & Espresso Machines
<!-- from fixya rte -->CLEAN ON MILK CONTAINER NOT WORKING - Coffee Makers & Espresso Machines
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 137 Answers
Clean again whit water and salt.
Posted on Dec 09, 2014
3 Suggested Answers
  • 74 Answers
SOURCE: Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Posted on Jul 11, 2008
SOURCE: Milk container doesn't heat milk..only the steam is released.
I was told this was a problem with the O rings on the machine (you need to keep these clean or replace them (if necessary) to keep the milk container working properly).
I did this and still had the same problem. Turns out the top on the milk container needed to be replaced. It's $20 from Delonghi but at the time of this writing is out of stock (I have waited three seeks so far and Delonghi is supposed to be escalating my request).
I finally got frustrated with the whole thing and completely disassembled the milk container top (there are a total of 5 screws and you need to remove the froth control slider to get to one of them) and gave everything a good cleaning. Pay attention to the small orifice on the inside of the chrome tube that the milk comes out of. Using a dental gum cleaning brush or similar sized brush and some hot soapy water should get the dried milk residue out. Inside the top is also a rubber piece that the froth regulator inserts into. Reomve this rubber piece and clean thoroughly. Make sure and clean all other areas inside the top with hot soapy water. Make sure to look the top over well as you disassemble to be sure note all component positions for reassembly. Make sure when reassembling that the cleaning button and its spring are reassembled correctly. The small red O ring on the end of the cleaning button's rod should be cleaned well and the small tube into which it inserts should be free of any milk residue. One last item to check is the rubber bushing that rubber milk uptake tube inserts into is clean and making a good seal. Note that this bushing should make a good seal on both sides (the side the rubber uptake insrts into and the side the upper side of the top inserts into. Make sure all parts are reassembled correctly. In general if you clean and rejuvinate all areas that need to make a tight seal you should get good results. I have no experience here but it would be my observation that even with a good thorough cleaning job the results may not last a real long time as it seems that parts in the top show wear after about a year and a half of daily use. In my oppinion the purchase of a new $20 top makes sense, but if you can get one or don't want to wait you can spend the 30 minutes to do the above cleaning. Because of apparent backorder issues at Delonghi this may also be a good idea to buy upfront. Make sure to include the 5 O rings in the order ($1 each) to avoid paying two shipping fees. I have found one of the O rings at Lowe but was unable to find a few of the sizes (smaller than Lowes sells).
Posted on Aug 30, 2009
Water container not engaging to clean milk pipe
Try filling it up the whole way with water. The pressure it puts might affect something. Sorry if this didn't help.
Apr 17, 2016 | Miele Coffee Makers & Espresso Machines
Miele CVA5065 coffee machine- the manual states : "fill the big plastic container to the max level". What is the volume to the max level?
Filling The Water And Coffee Bean Containers - Miele CVA ...
www.manualslib.com > ... > Coffee Maker > PW 5065 > User manual
Miele CVA 5065 Manual Online: Filling The Water And Coffee Bean Containers. Thecoffee machine must be cleaned thoroughly (see ''Cleaning and care'') before you... ...up to the "Max." mark. A valve at the front of the water. container will ...
[PDF]Operating and installation instructions Built-in coffee ...
Nov 25, 2015 | Miele Coffee Makers & Espresso Machines
Delonghi esam 5600 will not froth milk
Here is the manual:
http://www.delonghi.com/Global/InstructionManuals/EN/ESAM5600%20Intro%20EN.pdf
Two causes from the troubleshooting section:
The froth regulator is incorrectly adjusted. • Adjust following the instructions in the section on preparing drinks with milk.
The milk container lid is dirty. • Clean the milkcontainer lidasdescribedin the section "Cleaning the milk container".
Feb 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
Milk not coming out of milk jug.
First make sure you have the tube seated all the way in, the one inside the milk jug. I had assisted with the same problem before and the owner did not put the tube back in after cleaning the milk container. Next add a little Petrol-Gel Food Grade Sanitary Lubricant to the O-Rings, should have two (a small black one and an orange one) on the machine that the milk container connects to. This will assist in creating a better seal. If either are missing then you found the issue. The O-Rings are critical to any pressure system, so keep them clean and lubricated. You can get Petrol-Gel at a restaurant wholesaler or Amazon.
May 15, 2014 | DeLonghi ESAM5500
The milk frother has stopped rotating.....the milk heats but the frother doesnt rotate hence no froth.... am in india,mmbai so dont know where i can fix it !
The solution to rotation issues with the frother have been soved finally by myself after reading all the suggestion. The fix is simple... Your attachments have been magnitised and need to be demagnetized. It works a beauty. Run a magnet around the metal rings. Hint. Never leave them on the the frother when not being used.
Jul 09, 2011 | Nespresso Aeroccino Automatic Milk Frother
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Aug 08, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
My delonghi magnifica is having a problem with milk..steam is coming through but no milk..can you suggest what the problem may be?
There are 'o' rings on the pipes (on machine - not milk container) where the milk container fits into. replace or clean them - should work like new.
Jun 21, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
