How to reset eprom pensonic tv
I want the service mode
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
What is the number of EEPROM used? The number of main system control memory IC? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 09, 2014
My pensonic tv when its tv mode has no color but when its dvd no problem.
Fault at its main digital board. Tuner problem. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jun 04, 2016 | Televison & Video
Can i reset to the original settings of my crt tv pensonic HG-2165FLT
You have to enter its service mode to make a reset. There are two ways to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 24, 2016 | Televison & Video
Good day!have ah pensonic model ctv-2155uv trouble is no picture in tv mode,but if u switch to video mode,no problem.only in t.v mode my atenna is no problem.
Your problem is with the tv tuner. Use a vcr tuner connected to your antenna, connect vcr to tv set video input and you have a working tv for normal reception.
Nov 18, 2015 | Televison & Video
Whats wrong with my tv?
This indicates that the TV somehow went into service mode, and the colors on your screen are a test pattern. There are a couple things that we can try to fix the issue.
The first, is to try and reset the EPROM in the TV.
To do this, remove the power cord from the wall, then press and hold the power button on the TV itself (not the remote) for 20 seconds. Then plug the set back in and power it up.
If this does not fix the issue, the last thing we can try on a user level, is to use the TV remote, and press Cursor Arrows UP then Down, and unplug power. Then plug it back in.
If this does not cure the issue, then this indicates a failure in the TV's EPROM which is what runs this Test/Service Mode, and there are no resets or adjustments you can perform to fix this. It is actually a fault in the component that generates this test, and the set would require service. There is nothing you can do that would enter the Service/Test Mode as a user, so this likely occurred due to hardware failure.
If your TV is still under warranty you can contact JVC from their service page for repairs below.
I hope this helps!
- Joe
JVC Official Service Providers site Purchase genuine JVC parts and...
Aug 28, 2015 | JVC LT-32D210 32 in. LCD TV/DVD Combo
How to reset EEPROM?
Hi Ahmed,
Please try putting a fresh EPROM. It may work. I hope you have tried remote options in the service menu.
Good Luck
Aug 08, 2015 | Televison & Video
Pensonic service mode
the unity has small switch for service, try to pass normal operation. Otherwise you must open the tv and see the switch for faulty or dirty try to clean with contacts cleaner solvent
God bless you
Jul 20, 2013 | Televison & Video
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
42hp66 toshiba will not change channels sits on channel 27. I do not have cable but the signal feeds other tv and this one was working this morning
I would say this has a software issue with the Eprom ic, I would try to get in the service mode and reset it to factory settings ( Google your model for service mode )
Failing this it will probably need a replacement av main board.
Mar 05, 2010 | Televison & Video
Phillips tv model #42pf5321d/37 we replace the signal board and we have picture now but the picture on the right side is too wide
You should have downloaded the eprom information onto a usb stick then transfered it back to the new board, or just removed the eprom off the old board onto the new. It is my recommendation to have an authorized service center come out and realign it within the factory service mode.
Dec 11, 2009 | Philips Televison & Video
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Electro Med Services...
