Question about Drills
How to remove the chuck on Makita model HP1640 hammer drill (there isn't any kind of screw inside, only a little hole) help please
  • 152 Answers
Grip a large Allen key in chuck then use a thin spanner wrench on spindle below chuck to loosen.
Posted on Jan 07, 2015
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Posted on Dec 31, 2008
rowdy45176
  • 2176 Answers
SOURCE: chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Posted on Jan 08, 2009
  • 142 Answers
SOURCE: Milwaukee magnum hole shooter drill cat #0234.1 chuck removal
counterclockwise
Posted on Jul 25, 2009
radar001
  • 1051 Answers
SOURCE: removing chuck from Makita 64C1 drill
secure the short end of an allen wrench in the chuck, making sure it is as tight as possoble. Useing a wood or hard rubber mallet strick the long end of the allen wrench so it turns counter-clockwise. This should loosen the chuck from the spindle enough that you can unscrew it by hand.
Posted on Feb 19, 2010
Is there a key to get a drill bit out on an older model Makita
yes it's a JACOBS chuck with a special key in a powertools shop you can buy this
information on
http://www.jacobschuck.com
If you have a drill in a chuck and it will not lose then
place the drill itself (not the tool) in a ,bench screw and take a little bench hammer with the point of the hammer against 1or 2 claws of the chuck and a middle heavy nylon hammer then you beat the machine slowly of the drill .
Succes
May 29, 2014 | Makita Drills
What keyless chucks will work on my makita hammer drill will a dewalt xrp chuck work on a makita
as long as the chuck is used for a hammer drill and the thread size is exact yes it will. I believe the thread is 1/2-20 and also make sure the chuck has a hole in the center for the reversing screw to keep it from loosening up. Let me know if you need more assistance. The thread size is usually stamped on the side of the chuck. Makita sometimes used a metric thread.
Dec 31, 2011 | Makita Drills
I have a makita BHP451 drill/driver with a keyless chuck and the gear box has striped out. I have a new gear box but do not know how to get the chuck off. I see a slot in the chuck that looks like you my...
The chuck has a left hand threaded screw inside. Turn to the right when removing the screw. Once the screw is removed you can remove the chuck by turning it to the left as it has standard, right hand threads. It is easiest to insert a large, L shaped allen wrench into the chuck, tighten the chuck, and hit the wrench with a hammer to spin the chuck off.
Jul 11, 2011 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Hammer-drill mode switch wont move to drill position
Try rotating the chuck to a different position, and trying it again. If it catches "between gears", it won't shift.
Best regards, --W/D--
Feb 18, 2011 | Makita HP1640 58Inch Hammer Drill
Makita HP 1640 hammer drill chuck loosens grip on drill while drilling
Sounds like the chuck is worn, happens frequently when used often. Here's the link to Makita, their contact info should get you some answers as to what part number is needed as well as the closest location to you for service if required. Hope this helps.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=316372
Jan 14, 2011 | Makita HP1640 58Inch Hammer Drill
How do I remove the Chuck from my Mikida 9.6 volt keyless drill
Dont know about a Makita, but my Craftsman drill , if you open the chuck all the way and look inside the hole where the bit goes, there;s a screw there that you can use to remove the chuck. amybe yours is the same way.
Nov 23, 2010 | Makita Keyless Drill Chuck Set, HP1501...
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
Damaged chuck
Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
May 14, 2009 | Makita 5/8" 2 Spd Hammer Drill
Keyless chuck removal
Yes you can use any kind if chuck as long as the thread that attachs it is the same size, look on line lots of tool stores sell them cheap.
Sep 22, 2008 | Makita HP1621FK 5/8" Hammer Drill Kit with...
Drills Logo
127 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
