Question about Drills
How to remove the chuck on Makita HP1640 hammer drill??
  • 313 Answers
SOURCE: makita 8444d mxt drill
what is the setting in your clutch. if you set the clutch to the highest setting and it`s still slipping then you need transmission assy.
Posted on May 29, 2008
rowdy45176
  • 2176 Answers
SOURCE: chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Posted on Jan 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: makita 6408 drill motor. can't see how to replace the chuck.
If you have the 6408 as listed the spindle is threaded and you are correct there is no retaining screw. What you would need to do is find a bent handle allen wrench about the size of the chuck capacity 3/8" and insert the shorter end in the chuck and tighten. put the chuck on a block of wood or workbench and position the long end at about a 30 degree angle in the counter clockwise position and strike it with a hammer, this might take a couple hits. If this is not a 6408 let me know and I will look at the tool for you and see what you got.
Posted on Jan 23, 2009
  • 100 Answers
SOURCE: Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Posted on Feb 16, 2009
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
What parts should I have beforehand if my Makita HP1640 has stopped hammering.The hammer switch seems to work and engage but little or no hammer action.
Here is the parts breakdown of your drill. It is hard to say exactly what is the problem, but #10, #13, and #17 have to do with the hammer action. #15 is the hammer switch. It also could be bad. good luck on that. https://www.ereplacementparts.com/makita-hp1640-5834-hammer-drill-parts-c-97_16247_40066.html
Jan 14, 2017 | Makita Drills
How to remove the chuck on Makita model HP1640 hammer drill (there isn't any kind of screw inside, only a little hole) help please
Grip a large Allen key in chuck then use a thin spanner wrench on spindle below chuck to loosen.
Dec 09, 2014 | Drills
I want to get the chuck off and put a new one on it how do i get it off ?
Hello. Here is the link to the parts breakdown (PDF file centre left) that should provide the reference you need. There is also a PDF for the owners manual if needed. Hope this helps.
Apr 04, 2011 | Makita HP1640 58Inch Hammer Drill
Hammer-drill mode switch wont move to drill position
Try rotating the chuck to a different position, and trying it again. If it catches "between gears", it won't shift.
Best regards, --W/D--
Feb 18, 2011 | Makita HP1640 58Inch Hammer Drill
Makita HP 1640 hammer drill chuck loosens grip on drill while drilling
Sounds like the chuck is worn, happens frequently when used often. Here's the link to Makita, their contact info should get you some answers as to what part number is needed as well as the closest location to you for service if required. Hope this helps.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=316372
Jan 14, 2011 | Makita HP1640 58Inch Hammer Drill
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
Drills Logo
134 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
