Ct 21q20e fuse of tv has out of order
My tv is out of order cause of fuse .i several times try to replace new fuse but the fuse is again out of order.
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
If fuse should blow up; certainly there will be a reason. A shorct circuit; an over voltage [Line] etc: Without make confirm about the reason, and rectifying it, do not replace an other fuse in place; and switch ON the set. It might make things more complicate. Contact any service technician. http://electronicshelponline.blogspot.com/
Posted on Dec 09, 2014
3 Suggested Answers
  • 2318 Answers
SOURCE: Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Posted on Jan 16, 2008
SOURCE: panasonic tv has blown second fuse in a week
You have a Voltage regulation problem.
Posted on Mar 15, 2009
Good Morning, Everyone!!!! I have an NEC CT 2020 A TV that recently went out due to a power surge. Is it better to replace the fuse on this model or buy a new tv alltogether????
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout in solving the problem...
Jun 14, 2011 | Televison & Video
Tv problem with a fuse
Your degausing thermistor is bad and needs to be replaced. The part number is D4DDF1R50001
Once that is replaced put a new fuse in put the set back together and you should be good to go. You will need to replace the fuse with the correct size and its part number is
XBA2A00101F
Sep 10, 2009 | Panasonic CT-36SX12 36" TV
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
NO POWER OR LIGHTS WHEN POWER BUTTON PUSHED
Hello and welcome to FixYa!,
It sounds like the Power Board on you TV has Died, you will need to replace it in order for your TV to work again
Hope this helps --Full Str Pka
Dec 30, 2008 | Panasonic Televison & Video
Keeps blowing fuse
It has a short circuit somewhere...
Not sure if this is a CRT, LCD or Plasma TV but the two common causes of shorts for CRT's are the Horizontal Output Transistor (HOT) and/or the Flyback Transformer (Could be both). As a general rule if the flyback has visible cracks in the case they should be replaced. It is also a good idea to replace the HOT if you're replacing the flyback as it could be weakened and may not last much longer itself.
Other areas to check for all types would be any Diodes in the Power Supply Circuit. If a diode is open it can cause the fuse to blow. Note that a diode itself will not short, but an open diode can cause a fuse to blow.
Mar 11, 2008 | Panasonic CT-32HL43 32" TV
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Won't turn on
Follow AC cord in to clip-in glass fuse....replace with SLOW
BLOW 6.3 amp ( T-type) Panasonic factory correction...T.
Dec 19, 2007 | Panasonic CT-32SX31 32" TV
Tv will not turn on
This set has a common problem with th main fuse opening for no other apparent reason... One of the few exceptions to my corner-stone statement that a fuse is never the cause only a symptom..
Don't replace it though with the same type grade, use a 6.3a slo-blow gma type - available at Radio Shack... Try that and if everything works you're back in business.. If not we nee to find a cause...
Bill
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
CT-32HL42 Panasonic will not turn on
These sets have a number of problems like yours which are associated with bad solder connections or cold solder joints. On this set one pin on the the start-up relay is usually open or intermittent The solution is to resolder connections on main p.c board. and especially on the vertical output IC. Also change the caps in the vertical section to avoid future problems. Scrivitron.
Jul 06, 2007 | Panasonic CT-27G13 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
