Question about Samsung Televison & Video
Samsung tv series sq01 has check fan 2 on screen then will shut off where is fan 2 located and what does this mean
Samsung tv series sq01 has had a warning sign that reads CHECK FAN 2 on screen then will shut off where is fan 2 located? and what does this mean?
    Master:
  • Samsung Master
  • 687 Answers
You will need the complete model/serial number for proper part#. To locate which fan is problem try watching to see which one is not coming on at start-up.
Posted on Jan 31, 2015
5 Suggested Answers
SOURCE: my samsung hlr5067 displays check fan #2 then will shut off
Well there is a possibility you might, if the fan doesn't look good I recommend you replace it. But don't go too far, maybe you just need to take off the dust on it.
Posted on Jul 22, 2009
falspet
  • 438 Answers
SOURCE: message on my tv reads check fan 1..
check fan 1 means the fan is not cooling, check to variety the fan is indeed working, the unit is shutting down due to over temp. if there is a filter, clean it
Posted on Jan 31, 2010
Mas Baz
  • 177 Answers
SOURCE: I am having a "Check fan #2" warning on my Samsung
Check fan is DMD fan defect.
Clean fan or replace it with the new one.
Posted on Mar 18, 2011
Testimonial: "Thank you very much, I will let you know how it turns out."
Mas Baz
  • 177 Answers
SOURCE: Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Posted on Mar 30, 2011
Testimonial: "THANKS "
My samsung 61in. Dlp screen flashes green/blue pic is viewable but everything is the two colors, also screen will flash icon check fan #1
You have 2 problems. Problem 1 either you main board or light engine is bad and needs to be replaced. Problem 2 is exactly what your TV says. Fan#1 isn't functioning properly so a heat sencor is being actiated to shut down your set. Make sure all the fans are free of debree and spinning. If one is not spinning, make sure it has voltage going to it. This will let you know if you have a bad fan, or a bad board.
Jun 05, 2012 | Samsung 61" Slim-Depth LED DLP HDTV
I have a 61 inch samsung TV. A message flashed across the screen saying "check fan # 1 " then a few minutes later it shut down.
Hello
Not much to do by web, this message mean you most likely need a new fan, tv shuts down due to overheating. Contact service.
Aug 21, 2011 | Samsung Televison & Video
Message on my tv reads check fan 1..
Jan 30, 2010 | Samsung Televison & Video
When you turn on the TV it takes about 20 to fully turn on. sometimes we get pink lines on the screen.
CHECK POWER SUPPLY BOARD ...OR REPLACED
POWER BOARD NO:
Samsung BN44-00167A BOARD, POWER (VERISONS SX07,SX05,SS03,SQ01)
Samsung BN44-00165A BOARD, POWER (VERSIONS SX08,SX06,SS04,SQ02)
Dec 31, 2009 | Samsung LN-T4065F Television
50 inch samsung flat screen television
fan # 2 is having problems; maybe missing voltage or broken fan
good luck
Sep 10, 2008 | Samsung TXM3297HF 32" TV
Samsung 50" DLP TV
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
Keep us posted.
Dan
Jun 27, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
112 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
