Question about Suncast 20"D X 30"W X 72"H, Taupe, Tall Resin Utility Storage C
My tally 7.2 not accepting voucher date other than 1st and 2nd.
How change date.
My tally 9 not accepting voucher date other than 1st and 2nd
I Think This Problem is related to Tally Accounting Software and not related with Tally Printer. Post your problem in Other section
Jun 17, 2014 | Tally T2250 Matrix Printer
To chage date of a voucher in tally 9, what steps to take
Open the Voucher which u want to change and press F2 then change the date as u need and press Ctrl+A to save it.
Jun 28, 2011 | Computers & Internet
Don't waste your time with educational version Better you try to download TALLY9(or what ever you want)+PATCH Torrent and read the README.txt file and do so.
Nov 19, 2010 | Tally T2250 Matrix Printer
How to change date in tally as per attachment?
To change the Effective date, press F2 in the Receipt Voucher entry screen. This will bring a small window that prompts you to enter the DATE and EFFECTIVE date.
If you wish to disable the EFFECTIVE DATE field, then use option "Gateway of Tally -> Accounts Info -> Voucher Types -> Receipt -> Alter" and then set the fields "Use Effective date in Voucher entries to " NO.
Sep 11, 2009 | Microsoft Windows XP Professional for PC
Aug 27, 2009 | Tally T2250 Matrix Printer
Cant change the date in tally 7.2
i have tally 7.2 software and i working on tally 7.2 bur before some software was lost and now i have install again tally 7.2 but i have chage the date period 1-4-2010 o 31-3-11 but it accep only 1 and 2 date it is not accepting 3 to 31 date so pls reply solution for this problem my emailid vatsnaina72@yahoo.in
Aug 03, 2009 | Tally T2250 Matrix Printer
How i change change voucher date in 7.2 tally
when i trying to enter date active only 1 & 2 day i just try to enter eg 3.4.2009 or 53.5.9, 3.6.9 not entering what i do. pls solve the problem.
Jul 17, 2009 | Tally T2250 Matrix Printer
How to find tally 9 short-cut keys
Tally 9 short-cut keys appear on the right-side of the tally screen. see the button names in the button bar.
few short-cuts:
Keys
Functions
Alt + 2
To Duplicate a voucher
Alt + A
To Add a voucher
To Alter the column in columnar report
Alt + C
To create a master at a voucher screen (if it has not been already assigned a different function, as in reports like Balance Sheet, where it adds a new column to the report)
To access Auto Value Calculator in the amount field during voucher entry
Alt + D
To delete a voucher
To delete a master
To delete a column in any columnar report
Alt + E
To export the report in ASCII, HTML OR XML format
Alt + I
To insert a voucher
To toggle between Item and Accounting invoice
Alt + N
To view the report in automatic columns
Alt + P
To print the report
Alt + R
To remove a line in a report
Alt + S
To bring back a line you removed using ALT + R
Alt + U
To retrieve the last line which is deleted using Alt + R
Alt + W
To view the Tally Web browser.
Alt + X
To cancel a voucher in Day Book/List of Vouchers
Alt + Y
To Register Tally
Ctrl + A
To accept a form – wherever you use this key combination, that screen or report gets accepted as it is.
Ctrl + Alt + B
To check the Company Statutory details
Ctrl + G
To select the Group
Ctrl + Alt + I
To import statutory masters
Ctrl + Q
To abandon a form – wherever you use this key combination, it quits that screen without making any changes to it.
Ctrl + R
To repeat narration in the same voucher type
Ctrl + Alt + R
Rewrite data for a Company
May 30, 2009 | Computers & Internet
Suncast 20"D X 30"W X 72"H, Taupe, Tall Resin Utility Storage C Logo
530 people viewed this question
Top Suncast Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Suncast Hardware and Accessory Expert? Answer questions, earn points and help others
