Question about HP LaserJet 3050 All-In-One Printer
Cant find scanner driver or software for hp 3055
Install print drivers, PLC6 it prints via usb okay but no detectable scan driver
  • Gpom Bard
    Gpom Bard Dec 09, 2014
    Nope that do work?
    For some reason it does no even see the scanner, so its a driver issue and I can't find the scan driver
    Sergeant:
    Champion:
  • 215 Answers
Hi
Use a Normal TWIN driver that appears in any software that allows you to scan or in Windows click on Start, Device and Printers, Select your HP3055 and SCAN
Posted on Dec 09, 2014
  • Paul Jones Dec 12, 2014
    Install then the HP Software:http://h20566.www2.hp.com/portal/site/hp...
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
Can print but not scan
Issue The error message 'An error occurred while communicating with scanning device' appears on the computer running Windows XP.This error occurs while using the HP scanning software. If the error message appears on the computer while scanning from a networked product, click here to troubleshoot scanner communication errors for the networked product (c00897542) (in English). This document does not cover the communication error message on networked products. Solution Beforeproceeding with the solutions in this document, use the product to makea copy in order to make sure that the hardware is functioning correctly. Ifthe copy function does not work, this document will not help resolvethe issue. Search the HP Web site for a document covering the errormessage that appears on the computer while copying. Ifthe copy function works, try each of the following solutions in theorder presented. After completing the steps for each solution, test theproduct. If the product still does not work, then proceed to the nextsolution.
NOTE: Someof the following solutions require that the computer be restarted.Consider printing this page or creating a bookmark to it, so that itcan be referenced after restarting the computer. Solution one: Restart the All-in-One and the computer Follow these steps to restart the product and the computer.
NOTE: Make sure that the product is connected directly to an electrical outlet and not through a surge protector or power strip.
  1. Turn the power to the computer off.
  2. Press the power button (c01453128.gif) to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the power button (c01453128.gif) to turn the product back on.
  6. When the computer restarts, try the scan again.
  • If these steps resolved the issue, you do not need to continue troubleshooting.
  • If the issue persists, continue to the next solution.
Oct 31, 2008 | HP PhotoSmart C4385 All-in-One Printer
Dear friend i have hplaserjet3055 i have installed by network i can print but i cant scan. it showing this error an error occurred during preview.if the scanner is being used please wait for it to...
Hi!
The problem described has nothing to do with the network or network settings. It looks like a driver/software related issue, the operating system cannot get accurate data regarding the status of the scanner.
Please download and install the latest drivers and software available at HP, especially for the scanning feature, here is a link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
Hope it works!
Aug 20, 2011 | HP LaserJet 3055 All-In-One Printer
Hi, the problem is i can not scan with the HP laserJet 3055 it prints via wireless with no problem but it says no set up on PC
You have to run the FULL setup on each machine for the scanner to work correctly. PLUG and play DOES NOT WORK very well, in that printing us the only function that works.... Go to HP.com and download and run the latest install software for your setup.
May 02, 2011 | HP LaserJet 3055 All-In-One Printer
HP Officejet J5780: Cannot scan, copy, or fax from my computer.
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Nov 12, 2009 | HP Officejet J5780 All-In-One InkJet...
Printer works scanner does not
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Scanner:
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Unable to scan on HP Laserjet 3055 on Windows XP
Sounds like a software issue - U might try contacting HP but do not hold your breath. If machine is out of warranty they want nothing to do with you and will refer you to some forum or whatever. Or they might tell you to get a new scanner compatible with a newer OS.
Jul 02, 2017 | HP LaserJet 3050 Printer
Scanning?
I had a similar and found out this model was particular about using "well-powered" USB ports. If you have a powered hub see if that makes a difference for you.
Aug 10, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055
i've upgraded my vista printer drivers and all and it still doesn't work ont he same model. i used to run this printer on a XP but working on seperate computer can be too crumblesome. since it's a plug and play on vista with this printer.. my solution is go to windows photo gallery. under the FILE - hit import scanner / camera. - it will auto read ur scan feature. but before that. just make sure u install a scanner onto ur windows . by going to control panels and set up scanner. - connect printer to computer first when u do that. it will rauto read ur printer. the drivers just owuldn't work but the windos software helps to elimiinate the problem.
Oct 19, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
