Question about Pioneer VSX-D307 Receiver
Left front speaker channel not working
It worked fine a couple months ago and just stopped and started making a fuzzy noise
  • Paul Jones Dec 09, 2014
    Check so all the wiring is not pulled or if the speaker cone is not damaged. Also control if the noise changes at all pressing the setting MONO/Stereo/Dual and verify with a headphone if the problem is also there on the left channel.
    Sergeant:
    Champion:
  • 215 Answers
Check that the green plug is properly inserted or it is not bent
Posted on Dec 09, 2014
Testimonial: "inside the unite"
  • lee absher
    lee absher Dec 09, 2014
    oh ya the ground part of it works bu not the positive
I bought this Acer aspire 7535g laptop off of my mum's friend which was in great condition when I bought it. The sound was perfect. Every driver was up-to-date. However now... 8 months on, the sound...
You can try booting a live linux CD or thumbdrive and see if that gives you sound. That will give you an idea if it's Windows or a hardware problem. If it's a windows problem try uninstalling and reinstalling your drivers. If that doesn't work keep searching around or just try a fresh install of windows.
Aug 27, 2011 | Computers & Internet
I have a Sanyo DCTS760 surround system. A couple of weeks ago i got a loud static noise coming from the front left speaker. I tapped gently but forcefully on the top of the reciever cabinet and this ,...
if the left front channel is not working, first test the speaker with the right channel that is working to make sure the speaker is still good.
If the speaker is good, then it means the fuse of the left channel has burnt. Open the receiver and check the left channel fuse.
Good luck.
Jul 21, 2010 | Sanyo Televison & Video
Lafayette LR-775 Receiver left channel problems!!1
This sounds like a pre-amp transistor breaking down or a defective coupling capacitor. Without seeing the unit and tracing a signal, I can't say for sure what the exact problem may be. This should not be a major expense though. If you are getting output tot he speaker, just crappy sound, the output section is most likely working correctly. Plan on a parts expense in the $10-$30 range for this repair.
Dan
Mar 09, 2010 | Audio Players & Recorders
Left channels do not work when using surround modes
Ohhhhhh, so it has NEVER worked for YOU and it needed fixing when you got it. That changes everything. And you don't have the manual??
You can find the manual on Retrevo.com. Just register and download it. You're going to need it to make use of this unit anyway.
Make sure everything is connected correctly.
Look it over and play around with it. Speaker setup needs to be done before anything else. Did you get the microphone that comes with it? If not, go to page 23 and start there.
Feb 16, 2010 | Denon AVR-1708 Receiver
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
JBL on rour stop working one hour later every time
Hi, I got my on tour a couple of months ago and it worked fine. But just recently it starts stopping emitting any sound one hour or so after I start it. No sound at all, and the light goes off too. If I press one of the buttons, the light will glim just once.
Aug 01, 2008 | JBL (JBLONTOUR) Computer Speakers
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Help
I recommend you swap your left and right input cables to make sure it's not a source issue.
So from your headunit, plug the left channel output into your amps right input and your right channel output into your amps left input.
If the same side is still not working then disconnect both (or single speaker if it bridged) the speakers from the not working side at the amp. Connect the front and then the rear speakers individually and retest to see if one of them works.
If one does work then check the cabling and speaker connections on the one that doesn't. If it's shorting out anywhere it will stop your amp from powering that channel.
Failing that, it could just be that your amp has partly failed.
Feb 15, 2008 | Boss Riot 1500D Car Audio Amplifier
Pioneer VSX-D307 Receiver Logo
63 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
