Question about Electrolux Kitchen Ranges
WHY DOES THE INDIVIDUAL COOKING ZONES ONLY WORK WHEN THE LEFT FRONT COOKING ZONE (180mm PLATE) IS TURNED ON AND YET THE LFET FRONT COOKING ZONE (180 mm PLATE) WILL NOT WORTK WHEN TURNED ON BY ITSELF O
THE HEAT INDICATOR LIGHTS ALSO GO OFF WHEN THE FRONT LEFT PLATE SWITCH IS TURNED OFF BUT THE PLATES ARE STILL HOT
    Sergeant:
    Champion:
  • 215 Answers
There are 3 answers possible for your question:
1) your heater has a Thermolimiter without Hot Warning Light indicator connector and the job is dne by the electronics tht manage the zone. In this case the timer indicates that the hob is cold but obviously it is not. The fault is at the Electronics.
2) The Heater is a double Zone (with an inner ring and/or an oval side) in this case the part that it is failing to switch on is activated only in the sequential Inner ring-Outer ring. If the temp of 550C is reached the Thermolimiter does the cut of power cycling +/- 50C in order to avoid exceeding the 550C nominal.
3) Wrong Wiring if the heater was replaced. The harness could have been swapped around. Heaters could be Ceramaspeed or EGO that have inverted power and thermolimiter faston. Eika heaters are different too. but for this you need to see what is inside the hob and it is dangerous if you are not a qualified electrician.
Posted on Dec 09, 2014
How to reset miele model 5600 to factory default setting
This makes no sense to me, but the manual states:
^ Switch the hob on.
^ Touch the sensors for selecting the front left and front right
cooking zones at the same time for 10 seconds.
Nov 08, 2016 | Cell Phones
Child lock turn off
For the Candy CH642B cooktop:
LOCKING BUTTON OPERATION
The locking function prevents the children from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on.
To lock the hob :
- Press the on/off button
- Press simultaneously " - " button and " + " button of the front right zone (CH 633 front left zone), and then press again on the " + " button of this zone.
When the hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds.
To unlock the hob :
- Press the on/off button. The locking indicator " L " is displayed on all zones.
- Press simultaneously the " - " button and the " + " button of the front right zone (CH 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Dec 05, 2015 | Cooktops
I have beenunsuccessfully trying to find out the current draw for the h2661bp oven and the km6366 cooktop so i can select a cable size forthe installation. Can you help me please. Cheers ian
All individual PowerFlex cooking zones 150 - 230 mm ?, 2100 W, TwinBooster 3000/3700 Watt
PowerFlex cooking areas: Left 230 x 390 mm, 3400 Watt, 3700 Watt Booster
PowerFlex cooking areas: Center and Right 230 x 390 mm, 3400 Watt, 4800/4700 Watt Booster
Total power: 11.1kW
Feb 01, 2015 | Cooktops
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
My Zanussi Induction cooker model ZKT 621LX is not working? When I try to switch it on, the display for all 4 cooking zones shows L and after a few seconds, it just shuts off? What could be the problem?
Hello Horus,
The child-lock has been activated - probably accidentally, but someone may think you're not safe to use it. The de-activate the child lock . . .
1. Switch the cooktop on so all zone show "L"
2. Press both the + sign for the right-front zone and the - sign simultaneously. All four zones will show "0" with flashing decimal points.
3. Press the - sign again. The cooktop will switch off.
You can now switch the cooktop on and use it normally again.
Hope this helps. If you have any difficulty de-activating the child-lock or need further assistance, please let me know.
Regards,
BElectric.
Apr 19, 2011 | Zanussi 23 in. ZKT641H Electric Cooktop
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
Kitchen Ranges Logo
107 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
