Question about Brema CB425A Air Cooled 102 lb Ice Cube Machine w/Bin
Hi I have a brema ice machine and it's not letting the water go through the solinoid, I have cleaned out the pipes and replaced the solinoid, any ideas ?
  • 4 Answers
I know this sounds like a silly question, but is the solenoid good (I've had new bad ones bfr. If you have a voltmeter put on ohms in kohms position and you should get at least 4k ohms. Flick thru the ohm settings and see if you get a reading. Also check that you haven't accidently put on backwards check to see if board is supplying voltage to the solenoid.
Posted on Dec 09, 2014
Testimonial: "Thanks I'll get a friend to check it out"
Water dispenser doesn't work
Hi Eugene Perillo
Check where the water comes into the refrigerator and you should have a solinoid valve...maybe two...if only one...replace the valve, it is defective or has debris or dirt causing the valve not to work...if you have two solinoids then replace the one that feeds the water to the dispenser because it is defective.
Bud
Sep 23, 2012 | Refrigerators
My brema ice machine dsnt wanna work, it just stopped. do they have reset buttons
Not really.
Check water supply and filter first. Then check to make sur the fill valve in the cube tray has not frozen shut.
It might only need to be defrosted and refrigeration coils cleaned of dust and debris..
Jan 15, 2012 | Refrigerators
ICE MAKER NOT GET WATER
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...the temperature(it needs to be 0-4 degree F for the ice maker to start) may be defrost problem send me a note if you need info on that
Aug 24, 2009 | Amana SXD524VW Side by Side Refrigerator
Water solinoid staying closed when turned on
Usually energising electricity to a solenoid will allow the water to flow. Try your unit with the water line from the solenoid unattached. Then you will know when it is trying to get water to the ice maker.
Apr 28, 2009 | Refrigerators
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Jan 02, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
New install
The machine is suppose to start filling, then after 45 seconds or so turn on in the harvest mode then when the temp gets where the sensor says its suppose to be it starts to freeze.
If water keeps coming out the over flow the water valve may be stuck open and this is why you can't make ice its letting in warm water all the time. Try turning the water off to it and see if it freezes a batch. If so replace the water inlet valve or remove and clean it
Dec 12, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Sub Zero 532 Freezer Not Making Ice
These all sound like there is no water coming into the ice trays. The main water valve where the water feed line comes into the unit is probably plugged or not working at all. The solinoid may not be opening the valve..If you can operate a voltohm meter then test the solinoid coil to see that it is good by seeing an ohm reading below 1000 ohms. Also if you are crafty enough you could unplug the wires from it and connect 110vac directly to the solinoid coil to see if it clicks and lets water run in.. Also be sure the water is coming to the solinoid...If water is coming to it and the solinoid is letting water go through when fed directly with 110vac the problem is in the control circuit that operates the ice maker.
That problem would be on the Ice maker itself...
Jan 05, 2008 | Sub-Zero 632 / S
Brema CB425A Air Cooled 102 lb Ice Cube Machine w/Bin Logo
273 people viewed this question
Top Brema Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Brema Kitchen Appliances - Other Expert? Answer questions, earn points and help others
