Question about Fargo HDP5000-LC ID Card Printer Dual-Sided with Lamination - Configurable
Fargo HDP5000 error 231
Lamination Part
2 Suggested Answers
cardprinterp
  • 3 Answers
SOURCE: ribbon miscue on cyan fargo hdp5000
There are a few things which could lead to a ribbon miscue. The most obvious would be your firmware. Go to Fargo's site and download the latest firmware patch. Your printer may driver be corrupted, so uninstall and then re-install it. One other possibility is that your printer has a faulty ribbon sensor which would need replacing. I hope this helps
Posted on Sep 04, 2012
How to solve error 128 Fargo hdp5000
That error code indicates that a ribbon calibration should be performed. Please download the (free) Fargo Workbench Utility program (Drivers Downloads), and perform the ribbon calibration from the Printer Information tab, and then testing screens within.
Feb 13, 2018 | Fargo Office Equipment & Supplies
Draggingclutch
are you talking car or lawn mower
have you just fitted a clutch kit or what has belts to do with it
when making a sentence use breaks between the words so that sense can be made of the statement
Jul 30, 2016 | Miscellaneous
ERROR MESSAGE 246
There was a communication
failure between the Printer
and Laminator.
FARGO Electronics HDP5000 User Manual Page 96
Feb 25, 2016 | Fargo HDP5000 ID Card Printer Dual-Sided -...
Fargo HDP 5000 heater error 161 fault
This error usual occurs after a large print job (50 prints in a row). Try shutting off the printer, and leaving it off for a good 15 minutes. Turn back on and retry.
If the problem persists, then you should contact a service center. It seems to have a failure in an internal sensor.
May 06, 2014 | Fargo HDP5000 Thermal Printer
What is the difference between cold and hot laminators?
Hot laminators are the most common types of laminators. They use heat (220 to 300 degrees F) to apply the lamination. Hot laminators provide a better quality lamination that is more resistant to wear and tear. This is the preferred method of lamination for materials that are not effected by heat.
Cold laminators use pressure sensitive adhesives to bind the lamination film when the material being laminated is sensitive to heat. Certain inks in standard ink jet printers are known to have the ink melt in the machine. There are other types of printers that use heat sensitive paper. For these types of applications the cold laminator is the best choice.
Jan 28, 2013 | Office Equipment & Supplies
What is a laminator?
A laminator is a tool used to plastic coat documents to protect them. Your social security card may have a laminate coating.
Card Jam Error 112 & 245
please calibrate the Lam Film sensor.error 245 is lam sync error please check Lam power/connections and restart the Printer.
Oct 02, 2012 | Fargo HDP5000-LC ID Card Printer...
How can i turn on or off my fargo hdp5000
Fargo HDP500 didnt make any power on or off button you just need to remove the power cable direct from the printer and retuning it their also it will turn the power on
thanks
ED
Aug 30, 2012 | Fargo HDP5000 Thermal Printer
Lamination unit is not working properly
Check to see if there is some gunk or paste stuck in there.
Aug 18, 2012 | Zebra Eltron P520i ID Card Printer...
The message center say to check lam power and reboot required. How do I reboot the lam
Power unit off. Take Power cord off the printer.
Remove Lamination unit at the connector.
Check it for obstructions.
re-install the Lam unit.
Power up the unit.
May 25, 2011 | Fargo HDP5000 Thermal Printer
Open Questions:
Fargo HDP5000-LC ID Card Printer Dual-Sided with Lamination - Configurable Logo
253 people viewed this question
Top Fargo Computers & Internet Experts
Vernon Taylor
NOEL
NOEL
john h
Are you a Fargo Computer and Internet Expert? Answer questions, earn points and help others
