Question about Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER
Printer cannot turn on, after pushing power button only flashing a few second and back off. what i supposed to do?
I have check with another power supply, but still cannot.
    Problem Solver:
  • 10 Answers
Sounds like a short in your fusing unit. I have seen this happen by having a pinched wire in the fusing unit, this will cause your switch to turn off on its own.
Posted on Dec 09, 2014
  • hanDportgas
    hanDportgas Dec 10, 2014
    i've tried to find fushing unit, but didn't find any fuse, and tried to jumper each contact of push button, but the same problem still come out.. do u have another advise?..
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
Printer does not print
Instructions
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    My epson tx700 printer dispaly ink pad at end of life and printer not start
    A fix from a forum:
    Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
    1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
    2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
    3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
    4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
    5. When the paper-out LED flashes, release the buttons;
    6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
    7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
    Procedure 2
    2. Hold down the paper feed button only;
    3. Turn on the printer;
    4. As the paper feed light starts flashing, release the button;
    5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
    6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
    Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
    1. Switch off printer with panel switch;
    2. Switch off printer at mains switch - leave off for 20+ seconds;
    3. Hold down roll feed and sheet feed buttons;
    4. Switch on at mains;
    5. Switch on at printer panel;
    6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
    7. Switch printer off and then, after a few seconds, on again at mains switch;
    8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
    9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
    10. Release the roll feed button and all should be well.
    Apr 25, 2011 | Epson Printer
    The ink pads are at the end if their service life.
    Depending on what type of printer you have:
    Procedure 2
    Mar 13, 2011 | Epson Office Equipment & Supplies
    When I try to send a fax I get a redo message and no pages are sent...i have sent many faxes to this number....a message appeared after one page was scanned that said to prress clear and srop...i could not...
    Please reset the Printer by following these steps:
    Feb 27, 2011 | Canon MX310 Office All-In-One Printer
    I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
    Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
    Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
    Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
    Press the "Resume" button four times once the green flashing has finished.
    Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
    Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
    My yellow color is not printing. I change cartridge twice, run a few times cleaning process, but no even a dot of yellow color on the paper. What should I do?
    Hi
    Thanks for using FixYa. There are two step-by-step procedures to resolve the issue—
    Procedure 1
    1. Turn off the printer and ensure that the print head is at its home location and locked in place as normal;
    2. Power off the printer at the wall or by removing the power cable for at least 20 seconds;
    3. While you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1;
    6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds then release the button;
    Procedure 2
    1. Turn off the printer and ensure that the print head is at it’s home location and locked in place as normal;
    6. Allow printer to complete its processing then turn it off for a few seconds and turn it again on.
    By following any of the above step-by-step procedure, the printer will start printing normally.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Oct 29, 2009 | Epson Stylus CX6600 All-In-One InkJet...
    Power light flashing and red light on button 2 will not print
    Hi
    Procedure 1
    7. The printer will now attempt to reset, including resetting the EPROM memory and running a short (about 10 seconds) cleaning cycle.
    Procedure 2
    By following the above any one of the step-by-step procedure, the printer will start printing normally.
    Thanks
    Rylee
    Oct 03, 2009 | Epson Stylus 680 InkJet Color Printer
    Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER Logo
    53 people viewed this question
    old marine
    old marine
