Question about Cuisinart EM-100 1000-Watt 15-Bar Espresso Maker, Stainless Steel"
The light goes on. I can feel the water is heated. Machine makes a lot of noise, but water doesn't pass from resivoir thru to frother wand or thru coffee filter. I am just running water to te
Removed water tank and put pressure on foam like filter at bottom of tank to see that water moves thru it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
It needs to be descaled. After that, turn and try to make coffe but without the cofee. Turn on the steamer nozzle at the same time, that will draw the water to the coffee area, in fact try that first.
Posted on Dec 11, 2014
Filter change
this was absolutely the problem with my Jura Capressa E-8 machine. I followed instructions after changing the filter. I opened tap-machine stated that it was filling system- I closed tap when instruction. The open tap remained on because no water was filling system. I took the frother tip off and opened tap. Water filled system (container under frother). I closed tap without the frother tip. Machine Ready.... (I heated water in microwave for three minutes) I placed the frother tip in there and used a wooden skewer to ensure frother was clear of debris... Worked like a charm!
Nov 26, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
Ascaso dream wand wont heat or steam
You should descale the machine, as you may have a blockage in the steam tap.
When descaling make sure that the descaled water goes through the steam wand as well as the group. JURA descaling tablets
Mar 26, 2017 | Ascaso Dream Espresso Machine
How do I operate this Gaggia Fantastico II Espresso machine?
http://kitchen.manualsonline.com/manuals/mfg/gaggia/gaggia_espresso_maker_product_list.html
Sep 06, 2012 | Coffee Makers & Espresso Machines
How do you clean the frother on the ESP8XL machine?
1. Remove the froth enhancer and rinse under warm tap water. 2.. Wipe the steam wand with a damp cloth. 3. Briefly set the Selector Control to the ‘STEAM’ position to clear any remaining milk from the steam wand. If that doesn't work, remove any rubber parts. Place the metal frother tube in a pot of water with a bit of ammonia or vinegar in it. Heat the water to boiling, then let it simmer awhile.
Nov 08, 2009 | Breville ESP8XL Espresso Machine
The frother on my cafe roma has stopped working. I removed the wand but where the steam comes out is stopped up. how do i fix this
The "frother" is probably blocked. Remove it and see if you can blow through it. If not, you can try cleaning it with a paper clip. If that won't work, place the metal frother tube in a pot of water with a bit of ammonia or vinegar in it. Heat the water to boiling, then let it simmer awhile. After it cools, try using the paper clip again. You should clean the steamer attachment after each use:
2. Remove the froth enhancer and rinse under warm tap water. 3. Wipe the steam wand with a damp cloth. 4. Briefly set the Selector Control to the ‘STEAM’ position to clear any remaining milk from the steam wand.
Oct 30, 2009 | Breville ESP8XL Espresso Machine
No steam pressure with little to no water/steam
Remove the steam wand and inside you will find a small teflon like tube at the top, throw that away and run water through the wand to make sure it is clear then re-assemble in machine and test.
Jul 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Extremely loud squealing noise during steaming milk
This could be blocked. The best way to clear this is to switch off the machine and see if you can dismantle the frother arm. Sometimes the arm will come off by unscrewing. If it does, wash it in hot water and washing liquid. If it doesn't come off try putting the frother wand into a mug of cold water and allow it just to steam the water.
Frother wands don't just steam liquids - they **** up liquid which can block the vents and the actual steam hole which this machines' problem sounds like it does have.
Apr 05, 2009 | Breville ESP8XL Espresso Machine
Milk is heated but doesn't produce adequate froth
Inspect the end of the frother nozzle you should see a small plastic piece protruding.
If you dont see it remove the lower half of the frother and insert a pen and push the plastic insert to the end of the frother.
A "click" should be heard when it is located correctly.
Feb 21, 2008 | Gaggia Titanium Espresso Machine
Bodum Granos 3020 Espressoo Machine
Last year I stripped the machine and found the blockage in a diverter valve. This device switches between the coffee making head or the steamer. I had a blockage in the diverter causing the solenoid to lock in the coffee position that was also blocked. I flushed the system out with Oust cleaner.(very quick and effective) I then reassembled the machine and put sachet of oust with four times as much of filtered water. Then I switched the machine on and passed half the through the coffe head and steamer at full heat. Left for 10mins. then passing the rest through, cleaned with filtered water and away it went. Fixed!!! email gethudall@hotmail.com
Feb 18, 2008 | Bodum Granos 3020-16 Espresso Machine
Cuisinart EM-100 1000-Watt 15-Bar Espresso Maker, Stainless Steel" Logo
350 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
