Computers & Internet Logo
Jimmy Marsh Posted on Dec 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Still cant get it to recognize boot device. Or exit setup
Vladimir Frolov
Level 3:
  • Computers & ... Master 2,075 Answers
  • Posted on Dec 09, 2014
Vladimir Frolov
Level 3:
Answers
2075
Questions
Helped
415530
Points
6445
More details please. Do you have GPT file system on the booting dev?
Aspire 3690
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard drive.
  1. Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
  2. If your CMOS Setup has an option to boot from the LAN disable this option.
  3. If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
Finally, if none of the above suggestions resolve this error go through the Invalid or Non System Disk error troubleshooting steps, which is related to this error message.
Cant find Windows Installer and my XP restore plus will not open
My suggestion would be to go into BIOS Setup, and in Boot Options; change the first boot device to CDROM.
Computer off. (Press the Power On button in for a count of 10 seconds, or until computer turns off)
AS SOON AS you press the Power On button, start tapping on the F10 key.
Tap in 2 second intervals.
If you hear beeps ignore them. They are Stuck Key Error Code beeps, and it is You that is doing it. (It's OK)
Takes a few seconds, then you should be looking at the Main menu, in BIOS Setup,
System Information
Standard CMOS Setup
Advanced BIOS Features
Advanced Chipset Features
Integrated Peripherals
Power Management Setup
PnP/PCI Configuration
PC Health Status
Load Optimized Defaults
Supervisor Password
Set User Password
Save and Exit Setup
Exit Without Saving
You CANNOT use your mouse anymore. You need to use the Keyboard.
Use the Down Arrow key, and highlight Advanced BIOS Features.
Press the Enter key.
First Boot Device
Second Boot Device
Third Boot Device
Fourth Boot Device
You want CDROM as the First Boot Device.
This FORCES the computer to boot off of a disk in the optical drive.
(CD/DVD drive)
So you will want Optical Drive as the first boot device.
BIOS Setup changes. There are different versions.
The manual is unclear, of how to move Optical Drive to the top of the list, or also can be said as move to First Boot Device.
Let's see if this method is used;
Use the Down Arrow key, and highlight -> First Boot Device
Now press the Enter key.
Use the Down Arrow to highlight Optical Drive.
Now look at the navigation guide at the bottom. (Does NOT state navigation guide)
Use the appropriate keys to Change Value.
It should either be the + / - keys, or the Page Up/Page Down keys.
(If you can, I would use the Minus { - } key, and not use the Plus
{ + } key )
Tap the key until Optical Drive is at the top of the list, or across from First Boot Device.
Now use the Up or Down Arrow key to highlight -> Save and Exit, and press the Enter key.
Don't have your Restoration Disk in the optical drive?
That's OK. Open the drive, put it in.
Now press the CTRL, ALT, and DELete keys AT THE SAME TIME.
This will restart the computer.
For additional questions please post in a Comment.
Regards,
joecoolvette
HP Support > Service Reference Guide > HP Compaq DX2200 MT Desktop PC,
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00631987/c00631987.pdf
2answers
Samsung NB30. I cant get into the Boot menu. When switching on the laptop it appears on the screen "BIOS shadowed". I dont have the password for loggin into Windows XP home ed. Also it seems that th
After powering on the NB30 laptop press F2 until it goes to setup page. At setup page press left or right arrow until cursor is in Boot page. In Boot page select the Boot device Priority then press enter to go to another page. Select USB HDD then press x to enable it. Then press F5 of F6 to bring the usb in No. 1 in the list. Press F10 to save and exit. Connect a bootable USB dongle and re-boot the laptop.
I have a8v-vm motherboard...my ad dvd writer was not working.so i purchased new sata dvd rom but now problm is thai i cant boot from it or instal xp buy this......what i do now..what is the setting in...
Restart your computer.
Press <DEL> to enter BIOS SETUP.
Look for "Boot" options, and change the "Boot Order" to make the CD/DVD the _first_ boot-device.
Save/Exit from BIOS SETUP.
Boot from the CD/DVD drive.
2answers
Gateway mx6453 wont boot up- oper system not found
Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
if you get msg opperating system not found use the system restore disk
Hope This Helps good luck
Please leave feedback
I have an Acer Aspire One notebook. I cant seem to start it. I turn it on and this displays : Check cable connection..! PXE-E63 : Error while initializing the NIC PXE-M0F : Exiting Intel PXE ROM. No...
It happens when no boot device is selected, the default is network boot first, you must select CDROM/DVDROM or HD as your first startup device. boot up machine and enter bios setup think its F2 key to enter bios generally it del or f1 or f2 it may say onscreen at start if f2 doesnt work
in the bios set boot order to HD as firstboot option then save and exit
hope this helps
dont know if all acers do this but also if you press f12 on boot up it gives you current boot options select HD that way is current boot and would have to be done everytime
Pavillion 552w cant get pass Award BIOS setup utility screen
hELLO THERE
First you will need to check the battery to see if it is low and needs to be replaced.
next boot the machine into bios and make sure that the time and date are set next select fail safe setup or
use the default setting also make sure that the harddrive is being recognized and is being loaded once the post is complete ok?
than save and exit and reboot .
best regards michael
1helpful
2answers
No operating system
start ur computer
hit delete to enter setup
go to the second title of the setup ( i forgot wats called heh..)
go to first boot device and choose cd rom
exit saving changes and restart ur pc
u will see the phrase ( hit any key to boot from cd)
hit any key and start the installation.
ps: try to get windows xp sp2 ...its good
Hard drive stops booting
Hi, If your computer stops booting from the hard drive and is asking for a boot disk, then: 1. The motherboard/PC is no longer recognizing the hard disk; 1.1 Go to your CMOS/BIOS setup and manually detect the hard disk, save & exit. 2. The CMOS/BIOS is set to boot from other devices such as CD, FDD or USB but not from the HD. If after configuring the CMOS/BIOS and the hard disk is not recognized, then it is probably defective and therefore need to be replaced. If the hard disk is recognized but will not boot, then some files of your OS needed to boot are missing, corrupt or overwritten. You would need to re-install your OS and opt for a "repair". Hope this be of some help/idea. Post back how things stand or should you need additional information. good luck and kind regards.
Need boot load for emachine T2484
Hi, You need to enter your CMOS/BIOS setup and set your "First Boot Device". Immediately after powering up, press the "Del" key, display will show CMOS/BIOS settings. Verify that all your hard disks are being detected/recognized by your PC. Thereafter, set your First boot device to your new HD. Save and Exit. Hope this be of some idea/help. Post back how things are or should you need additional information. Good luck and kind regards.
Grand Canyon Tech
Grand Canyon Tech
