What he did was take his old Dell running a Lenux program, and put a drive running windows 8 with it. I guess he was trying to run a double operating system. We have heard that the two can coincide together. He removed the floppy. And doesnt know where it is. But he cant get out of setup now
    Sergeant:
  • 238 Answers
It is never a good idea to install windows in multi boot last. Windows loves trashing bootloaders to try to get rid of any non microslop os. Try repairing the bootloader. Search on the name of the distribution + repair bootloader. You really need to give more information to get a good answer. It sounds like you need to do a little more studying if you are attempting something like this.
Posted on Dec 09, 2014
techniwiz
  • 275 Answers
SOURCE: ''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Posted on Nov 11, 2008
map9966
  • 2351 Answers
SOURCE: setup and bios
To get into the bios most pc's want you to press the Delete key on the keyboard. As soon as you start the pc up, press every 2 seconds. Other pc's want you to press F2 or F10 & some F12. One will get you into the bios. Once into the bios go to boot.
Make sure your cdrom is listed before your hard drive. Save & restart. Put your win98se cd in the cdrom & the system should boot to it. When windows finishes make a bootable floppy disk for yourself.
Enjoy!
Please vote...
map
Posted on Jan 28, 2008
  • 233 Answers
SOURCE: Error loading operating system
Try reinstalling Windows on the 80GB HD in the Compaq.
Posted on Dec 15, 2008
MPetro302
  • 298 Answers
SOURCE: dell dimensions 3100
sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
Posted on Apr 16, 2009
whitebirch
  • 433 Answers
SOURCE: cant reinstall windows because it sayd it cant find a hard drive
two things, check your jumper setting, if it is an IDE hard driver.
Second the computer usually won't recognize the Hard drive until it is formatted for the first time. Did the computer stop and say it could not find hard drive ? and you got F1 to continue, well if you did, just continue. Error 655D is a registry screw up, unplug your usb stuff if you can. remember your drivers aren't installed yet (usb requires drivers-once windows is reinstalling your get the drivers...good luck if you need any more help, just let us know
Posted on May 09, 2009
Can cyber chess download to windows 10?
Hi , do you mean that the subject program will not install using Windows 10 operating system ?
If so , try running the app's setup program located on the install disk media in compatibility mode for an earlier Windows version such as XP sp3
Compatibility mode enables a late version native Windows to run a program as per a user designated earlier version Windows and so extend support for obsolete apps that may not run using default settings
Navigate to the install disk's file directory using Windows Explorer (not the browser) , click on the folder to open and scroll down to the setup ( application) file . Right click to open the context menu and select properties > compatibility : check : run this program in compatibility mode and select from drop down list XP sp3 (my guess) or latest published supported Windows version for the subject app.
Check under privilege level : run this program as an administrator
click apply > ok then close and double click app's setup file to launch installation
Hopefully will now install and app will subsequently launch and process correctly.
Jan 28, 2016 | Computers & Internet
On a Dell optiplex gxa, running lenux after my son tried to transfer a hard drive from a hp running windows 8, I cant get out od a boot loop. Is there some way to get it to boot
Try the linux install again. Don't format, and it should hang on to all your files. If you have important files that you haven't backed up, you might want to search for a linux repair distribution. I'm usually hacking someone's lost password, which is a different war. If your bootloader, is trashed, a reinstall should fix. Windows loves trashing boot records, so I'd avoid letting windows anywhere near the system. you don't mention which bootloader you use, so search for repair bootloader + the name of the bootloader or the name of the distribution, like grub or lilo for the bootloader or ubuntu or mint, etc.
Dec 09, 2014 | Computers & Internet
How to compress hard drive and clear memory on a inspiron 1520 laptop
Some of your terminology might be off. I might guess that your Dell 1520 laptop is approaching 7 years old and runs Windows Vista. Your can run Disk Cleanup (found under All Programs > Accessories > System Tools). You likely have many programs running in the background when your startup your computer. You will need to go to the Control Panel > Programs and Features; then removed any unwanted programs. If you are really out of space on your hard drive, this steps will help a bit, but there will be only so much you can do at this stage.
Aug 30, 2014 | Dell Inspiron Computers & Internet
New hard drive/how to install Windows
the new hard drive has to be Formatted using the format command. look up dos format command or a utility program. then you have to reinstall Windows ?(whatever you had i guess) on the pc. any drivers disk for that pc needs to run after you format the hard drive and before installing the Windows operating system. exactly how depends. go on the HOW TO search site to find the exact steps -
Nov 20, 2013 | Dell Inspiron Computers & Internet
I recently had to give up on my old computer with Windows XP so now I have the dreaded Windows 8. Can you tell me how to transfer my Forget me not calendar to my new computer? I have tried "send to" a...
Windows 8 doesn't run Outlook Express. If you are having problems with an old Windows XP program, you are out of luck. You will need to buy a newer version of the program if it is available. Don't worry about hating Win 8, you aren't alone. Everyone hates it, even Microsoft.
Aug 19, 2013 | Broderbund American Greeting CreataCard...
How to use different system dell 610 old model laptop
An old Dell 610 maybe upgraded to Windows 7 but not Windows 8.
To check if your laptop can support Windows then run this program.
You can run a Windows 7 upgrade advisor to check if your computer is suitable for Windows 7.
Click on this link to download the check upgrade program :-
http://www.microsoft.com/downloads/en/details.aspx?familyid=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en
May 02, 2013 | Computers & Internet
How to install adobe photoshop cs3 to an old model computer
Look, here's a trick get yourself one of the new not-need-to-be-installed, Thinnapp, OR Portable Apps, These programs simply run by being Double Clicked, need NO installation, NO registration, and NO serial numbers etc. I include a link for a PS3 link get them all i just love them, you can put them on a USB drive and use it anywhere
rapidog.com/paint-shop-pro-x3-portable-rapidshare.html -
More apps below...
http://www.h33t.com/userdetails.php?id=122083
Mar 14, 2010 | Dell Microsoft Windows XP Home Edition
I purchased a printmaster platinum 12 in 2002 and loved it but now i am trying to download the software into a diffrent computer since out other computer crashed. i have my registration # but i can only...
I am guessing that your new computer has windows vista on it. That may be the reason Printmaster 12 will not install. Certain programs or their installations are not compatible with Vista.
I'm not sure what errors you are getting, and I am assuming you are running Windows Vista, so again I'm just guessing.
You could try to launch the setup program manually and using compatibility mode by following these steps:
1. Insert your installation disk.
2. Click the start button
3. Click on Computer
4. Right click on the drive containing your installation CD
5. Select Explore from the menu.
6. Find the Setup or Install file in the list.
7 Right click on it.
8. Select Properties.
9 Select the Compatibility tab at the top.
10. check "Run this program in compatibility mode for"
11. In the drop down menu select windows xp
12. check "disable visual themes"
13. Check "run this program as administrator" (if it is available)
14 click OK
15 now double click on the setup/install program.
I hope this solves your problem.
Thanks!
Nov 03, 2009 | Broderbund Printmaster Silver 12.0
Quickverse 4 wont run on XP with SP3
Try to run the program in the compatibility for ex windows 2000.
You do that when you right clik on the icon for the program on the desktop and then choise properties and then choise the last tab ( it is writing something like "compatibility" here you choise windows 2000.
Hope thats help
Aug 22, 2009 | Computers & Internet
Error msg 1335
Please try this. It worked for me. If you are on Windows XP, this can normally be resolved by setting the compatibility mode for Photo Explosion to Windows 98. You can do this by following these steps:
1) Click on the Start button.
2) Click on the My Computer. This should open a window titled My Computer.
3) Double-click on the C: drive.
4) If the information is hidden, there is normally an option to show the hidden files/folders. You will need to select this option.
5) Double-click on the Program Files folder.
6) If the information is hidden, there is normally an option to show the hidden files/folders. You will need to select this option.
7) Double-click on the Nova Development folder.
8) Double-click on the Photo Explosion folder.
9) Right-click on IPE40 icon, which looks like a camera.
10) Select the Properties option from the bottom of the pop-up menu.
11) Click on the Compatibility tab.
12) Put a check in the check-box next to "Run this program in compatibility mode for".
13) From the drop-down list, chose "Windows 98 / Windows Me".
14) Click on the OK button.
15) Reboot your computer.
Jan 12, 2008 | Nova Development Photo Explosion Deluxe...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
