Question about Makita Drills
Troubleshooting tips for Makita 18v li ion charger
Asked co workers
    Sergeant:
  • 206 Answers
Unfortunately the charger is an accessory and there are no parts available for it - it is a throw away and replace.
Posted on Feb 07, 2015
MarkDay
  • 111 Answers
SOURCE: Makita DC18RA Li-Ion 18V Battery Charger
Most likely, but unless the transformer blew, which is somewhat unlikely, a good repair shop should be able to fix it. Basically the charger unit is a transformer, some diodes to convert ac into dc, and some sensing circuitry to tell you when the battery is done charging. Diodes and sensing cisrcuitry are commonly available parts and not expensive. Transformers are expensive. Even if you get it repaired youll still need an adaptor to convert from the mains 240 to the 120 that the charger wants to see. Get one with a high enough wattage for the charger. Wattage is printed on charger base.
Posted on May 20, 2008
SOURCE: re: makita 18v lithium-ion batteries can
of course
Posted on Oct 04, 2008
SOURCE: problem charging makita batteries 18v
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 8 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. Buy Makita should definitely have a few words with their supplier before they become a liability!
Posted on May 25, 2009
SOURCE: I have a li-ion Makita BL1830 18V 3.0Ah battery
Sorry Mate your battery is dead...
The makita lithium batterys dont like getting worked hard quickly.
There is a chip in them that recognice each battery to each specific charger. Try another charger. This has not worked for me. Try anyway
Posted on Nov 27, 2009
rowdy45176
  • 2176 Answers
SOURCE: One question please, I have makita cordlless
according to the schematic I saw yes you can and I think that you will be pleased with its performance, their operator manual even lists the weight of tool with this battery. Makita has a 1 year limited warranty on the Li-Ion battery that you might want to consider if you have the receipt.
Posted on May 12, 2011
Testimonial: "thanks"
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
Why will a makita Li-ion 1.3ah battery not fit in other makita tools?
Some of the Makita 18v LXT tools require the BL1830 3.0AH battery and are designed that the 1.5AH battery will not fit.
Jan 12, 2013 | Makita 18V LXT Lithium - Ion Cordless...
I have a makita 6391D cordless drill with 18v ni-cd 1.3ah batteries, just had one battery and charger stolen so have to buy replacements is there any way i can convert it now to lithium batteries if
I can't find a Makita model 6391D drill but they do have a model 6390D drill that takes the 18V Ni-Cd pod battery. The tools and radio don't care what type of battery you use, only that they are 18V. However, to date, Makita does not make a Li-Ion, pod battery. All of their Li-Ion batteries are the slide-on type. Your options for that 18V tool is the 2.6ah Ni-MH battery (PN 193159-1 for a single or 194158-6 for a twin pack), the 2.0ah (PN 192827-3) and 1.3ah (PN 194107-3) Ni-Cd batteries.
Jul 06, 2012 | Drills
Three makita batteries wont charge 18v li-on
I did get an educated electronics eng. tell me li ion batteries 4handtools,are manufactured to only be recharged a set number of times,to avoid tool damage.
Oct 13, 2011 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
May 11, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Red and green light flashes alternatingly with only one of my batterys of my makita 18v li-ion fast charger
unplug charger to let it reset. plug back in and then try again, if it still flashes red/green that would indicate a battery failure. check for warranty replacement.
Aug 26, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a li-ion Makita BL1830 18V 3.0Ah battery that can't be charged...when on the charger the bottom two lights flash red..it will charge my other battery, so it doesn't seem to be the charger
Nov 01, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
60 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
