I have a craig cht904 surround sound system adn I cannot hear sound when connect to the TV. I can get radion reception, but that is it.
3 Suggested Answers
SOURCE: i want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
  • 108 Answers
SOURCE: On my craig surround system model no:cht904 the
Try to update it, if possible. Other solution would turn off the system completly from wall, for over 1 minute and try again.
Posted on Nov 13, 2014
How do I connect the Home Theatre System so that I can hear surround sound from the TV instead of through the TV speakers?
watch this ......copy the below item and paste it on google ....there it will show you the whole video...it will solv your problem
Nov 20, 2015 | Sony DAV-SR2 System
How do i hook up craig surround sound mode cht904
Are you using your TV for both Audio and video? Sounds like you are only wanting HD video and SS audio. If, so only send HD video signal to TV and keep SS Audio direct to speakers from SS receiver/ amp.
Jan 01, 2015 | LG Audio Players & Recorders
On my craig surround system model no:cht904 the buttons stopped working, it still turns on
Nov 13, 2014 | Audio Players & Recorders
HAVE A CRAIG SURROUND SOUND HOME THEATER SYSTEM WITH A DVD PLAYER HAVE GOOD SOUND BUT NO PICTURE WHEN PLAYING DVDS
Check whether you have connected your HTS video out put to TV/PROJECTOR 's Video input. Try HDMI port for better result.
Oct 31, 2013 | Craig 5.1 Surround Sound Home Theater...
Remote codes for craig cht904
271,238,226,290,281,000 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 12, 2013 | Televison & Video
I have rca home theater system rtd215 plays dvds fine but no sound when im watching tv programs i have no cable box just the jacks on my tv [52 projection screen phillips] and i tried hooking them into the...
This reson you are not hearing any "TV AUDIO" through your RCA surround system would be due to your tv sound output not being connected to an audio input into your surround system. You can hear DVDs,CDs and radio possibly mp3 if connected, as these are built in to the amplifier which the speakers connect to.
If the tv has a Line out (via phono plugs) and NOT via headphone out, connect it to an audio input on the RCA surround system. If the RCA has no other available inputs, well....there ain't a lot you can do but watch CSI with the sound from the TV and then Star Wars (for example) through the TV and Surround system.
Best Of Luck
Sep 03, 2010 | RCA RTD215 Theater System
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
Help! Surround Sound problems!
Since you have a surround sound system, you probably should just bypass the TV's audio.
Connect the red/white plugs from your digital cable box to one of the inputs on your surround sound system but not the Phono input unless the Phono input lists something aside from Phono, like Aux/Phono or CD/Phono.
Connect the S-Video or composite (yellow) video plug from your digital cable box directly to the S-Video or composite (yellow) video jack on your TV.
If your digital cable box does not have a S-Video (4 pins and flat rectangular hole) or Composite (yellow RCA jack) jack and only has the screw/push-on type cable with the pin in it, then leave the remaining connections as-is.
Now switch your surround sound system to the input you connected the red and white plugs to and turn on your TV. You should see picture from the TV, but hear audio from the surround sound system.
Apr 06, 2008 | Emerson EWF2004 20" TV
50 people viewed this question
 Grubhead
Grubhead
