We had a to turn the power off and now the air con operation and timer pre def is on and the air con wont work
We have tried turning it on and off but still flashing ilghts help
    New Friend:
  • 101 Answers
WHAT IS THE BRAND & MODEL? WHAT IS PRE DEF???
Posted on Dec 11, 2014
hvac1960
  • 2133 Answers
SOURCE: air con not working. Operation
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Posted on Dec 31, 2010
SOURCE: cant get air con to work it is a teco air conditioner
Ours did the same. My husband checked the manual and found that the filters were FILTHY! The filter is at the front of the inside unit. If you still have the manual it will show you where. This fixed ours as it was NOT working at all!!
Posted on Jul 28, 2010
bobotfel
  • 236 Answers
SOURCE: green light flashes 3 times will not operate
Its may be the thermistor is defective or out of range or the board itself, the unit will not operate unless the defective part is not replace.
Posted on Mar 09, 2008
  • 334 Answers
SOURCE: All lights are flashing including Pre Def, Timer,
Not sure the make and model of your equipment you have there but sounds to me like your control board is trying to tell you it is bad.
Posted on Jun 12, 2009
hvac1960
  • 2133 Answers
SOURCE: timer light flashing , turned
Remove the battery in Thermostat and re set it.Now start the unit.
Posted on Dec 06, 2010
Goodman minisplit flashes on pre. Def. Wont start
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Repair Tamarac
Apr 07, 2015 | Goodman Heating & Cooling
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Ilghts on cluster come on when backing up .can put shifter in neutral turn off and back on lights go out
sounds as if there is a short to ground in the shift column causing the lighting problem.
May 19, 2012 | 2000 Pontiac Sunfire
I HAVE A CHEVROLET SPARK MUZIC EDITION , MY REAR GLASS HAVE AN UMBRELLA EFFECT WHEN IN ILGHT
HOLA! necesito el codigo de desbloqueo de la radio de un chevrolet spark 2012. graciaas!
Mar 31, 2011 | 2012 Chevrolet Spark
Dear Experts, My Air con is not working, cant be turn on, there is blinking on the power . Tried to cancel the timer, it didnt work. Thanks Sri
To cancel the timer remove batteries in remote and reset it. and also reset the power with a/c unit. now you can operate with your remote.
Dec 30, 2010 | Heating & Cooling
I just bought a motorhome which has a webasto heater fitted, its has been working but now recently wont fire up. It tries to fire up, doesnt, the fan speeds up and the green ilght in the center of the...
Actually RV and motorhome insurance is not as expensive as you may think in many cases. This is especially true if you shop around and do your homework rather than just accept the first policy that comes your way. Of<a href="http://www.motorhomeinsurance.mobi/category/motorhome-insurance-guide" rel="dofollow">Motorhome Rental</a>
Dec 22, 2010 | Heating & Cooling
My panasonic airconditioner c9kkzw timer is always blinking and automatically turned off every hour. its driving me crazy becasue my kids won't asleep.. please please help me, tried turn and off but to no...
I think, you have set the timer for one hour. No problem, remove battery from remote and reset it and same way isolate the power to your air conditioner for 5 seconds and reset it. Now all pre programmed would have been canceled. Now you can set your temp as you like.
And another reason may be your compressor getting heated after an hour, due to dust blocked in your out door coil. Hence, please serive the unit at once. Thanks.
Dec 15, 2010 | Panasonic CS-A12C Air Conditioner
Heating & Cooling Logo
912 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
